Question about Compaq Presario 5000 PC Desktop
My son tried to clean my computer with a disc from his older compaq presario, now all my screen show is "invalid system disc,replace disc and press enter". I don't have the disc and don't know what it was,he's out of the country.
  • 1 more comment
  • johncox4 Jan 02, 2009
    no disc in the computer, and it wont let me do anything
  • Roberta Smith
    Roberta Smith May 11, 2010
    have you removed the old disk from the cd drive ?... if not remove it and reboot
    Robert
  • mircenaj May 11, 2010
    Is it still stuck in the installation?
  • Compaq Master
  • 787 Answers
Since there is no CD in the drive the computer is attempting to boot of the hard drive and not finding the files it requires (unless you have it set to boot off a USB device before the hard drive).
You cannot simply use the recovery disk from one system on another because these disks install drivers specific to the hardware of the computer for which it is intended.
You need to find the CDs that came with this system or contact HP and order them. Please note that running a recovery CD will wipe all your personal data from the system (this may very well have happened already), since this drive will not boot, connect it to another system as a slave or use a USB enclosure to see if there is anything you can salvage.
Posted on Jan 03, 2009
Once powered on it goes to black screen and says - INVALID SYSTEM DISC,replace the disc, and then press any key.
Are you sure the BIOS is set to boot from hard disk?
It looks like it is trying to boot from network (PXE) and then from floppy disk.
Jan 04, 2014 | Computers & Internet
No screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
Toshiba portege 2000 windows xp invalid system disk.
When booting, try going to the Boot Menu by pressing F12 when you see the Toshiba logo so you can select your hard drive as your boot device. After doing so, if you still get an "Invalid System Disc" error, then your hard drive may be shot.
Jan 04, 2014 | Toshiba Tecra 510CDT (P000224080)...
I want to remove win7 from my compaq cq57 laptop (intel core) and replace it with xp pro
In your case try the RAM part 1st.
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode).
  • Uninstall last program(s) that was installed, again in safe mode.
  • Re-install Windows. Clean install works best.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 01, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
I have a Compaq presario f700 model laptop computer that was working fine until last week now what happens is when I turn it on I get the hp logo on screen long time then it disapears and the screen...
Try to clean the Hard disc connector on your laptop motherboard or Sata controller if you are using sata hard disc. There is loose contact there try to clean it with a piece of paper.
Jul 19, 2011 | Compaq Computers & Internet
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
Not booting up; stopping at white Compaq screen
Take out the hard drive. Then turn the notebook back on and see if it goes past the Compaq screen. If it does then you know your hard drive is bad and it would have to be replaced. It could be shorting out the motherboard.
Jan 29, 2009 | HP Compaq Presario CQ50-211NR Notebook
Computer shows invalid system disc,wont let me do anything else
This might be simple.
Assuming your son didn't make any internal changes to your computer. The problem may be that he changed your boot sequence to boot to floppy or CD instead of the Hard Drive.
Do the following:
As your computer is starting you will briefly have the option to hit F8 (I think F8 Might be another) for "start up menu or options".
This will take you to a screen of text where following the on screen text areas and moving the curser with the keyboard arrows and enter or escape check your boot sequence (the order of where your computer is to look for start up information)
It should read as follows:
#1 HDD1 (this text may vary)
#2 CDROM drive
#3 FLOPPY (if you have one) or other removable drive
If your son changed this and forgot to it back your computer may be trying to get start up information from a CD or Floppy instead of your hard drive.
Once you've changed this (assuming you needed to change it) following the instructions use the key to "save changes and exit"
Your computer should now boot up correctly.
Let me know if this helps
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
Laptop wont turn on properly
A vital component that windows requires to run is corrupted. To fix it, you need the OS disc
In Windows Vista, there is usually a second partion on the harddrive that you can load by pressing F8 (or F10 depending on your system) and selecting the repair your computer option (depending on your manufacturer, you might need to input a password, after that choose the repair your computer option or solve startup problems
In Windows XP load the disc and open the recovery manager.
Jan 01, 2009 | Compaq Presario 700 470024-192 Notebook
System disc error Compaq Pesario 1275
This is either an issue with the CMOS batter which may need to be changed, I have seen this error on thinkpads and one way of resolving it is to install an older BIOS, you can download a BIOS from your machine and install it using there instructions
Hope this helps
Nov 24, 2008 | Compaq Presario 1275 Notebook
Compaq Presario 5000 PC Desktop Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
