Question about Kenmore 73053 Gas Kitchen Range
Element Burning Out on Kenmore Oven
Appears to be on fire! Do I need to worry? How do I install a new one?
  • Anonymous Feb 06, 2009
    I had the oven on when I noticed a glo thru its window. The heating element was on fire. Was able to remove pan and turn off oven. It burnt itself out. The element then broke part. I think I will get a new non-kenmore range.
    Sergeant:
  • 311 Answers
The elements short out internaly.happens all the time.it will look blistered and welded.it dosent mean any things wrong with your range.you just need a new element.and you turn off the power to install.God bless tom
Posted on Jan 02, 2009
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
Kenmore Elite 790.4671
Some Elite ranges were recalled for a fire hazard because of this sort of thing... check with a Sears Appliance store.
Dec 17, 2013 | Kitchen Ranges
My Kennmore 79363 Gas Range/ Electric Oven electrical doesn't work. Started smelling electrical burning smell, tracked to oven. shut off breaker, smell stoped. Few hours later checked again after...
The person who installed the oven didn't do the connections up tight enough.
I would replace the breaker/power switch with a new one and trim back the wires if the burning is in the breaker. If on the rear of the oven, same applies with badly tightened connections.
If in doubt, call a qualified electrician. That will be better than having a fire!
Aug 06, 2017 | Kenmore 79363 Gas Kitchen Range
Something went on fire behind the fan,there was a buirning smell and there was orange light coming from behind the fan. Now the oven wont heatr up
That fire and burning smell was your oven element burning out. The element is located directly behind the fan. This is why your oven will no longer heat up.
If you are going to replace the element yourself, there are some universal elements available (try eBay) much cheaper than the OEM replacement parts. You need to make sure it's the same rating though (e.g. 2000W) and is roughly the same dimensions and has the same fitting pattern.
You will also need a service manual unless you know how to get access to replace the element.
Oct 06, 2010 | Neff B1421 Electric Single Oven
Bake element got very bright then sparked and caught fire.
Hi, Just go ahead and replace the old element. It happens with no real reason. The new element should work great.
Vic
Jun 20, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Baking Element Caught fire
Elements wear out from the inside. Sooner or later it happens to all of them.
Mar 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
4th of July on 12/26
Yes the element failed and they will arc when they do that.Ive actually seen people hose them down with a fire extinguisher only to have it still arc. Bake elements are inexpensive and very easy to install.
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 73053 Gas Kitchen Range Logo
843 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
