Question about Reebok Exercise & Fitness
My reebok z9 exercise bike does not register any RPM/Speed/Distance/Calories
Everything else works fine, I think the issue may be with the sensor on the flywheel
  • 6 Answers
SOURCE: I need to know how to change from time to speed.
most likely there is a scroll or a function button on the console. By pressing that you can choose between the different functions of the display.  If yo dont have such button, look for something similar that will switch the data on the display.
Posted on Mar 17, 2009
greenspan
  • 1734 Answers
SOURCE: Wanted instructions for a Reebok RB1000 Exercise Bike.
If manufacturer and google are of no help, ask them. I guess they have the Reebok RB1000 manual for download on their site.
Posted on Aug 23, 2009
SOURCE: Handlebar on my reebok rb1000 exercise bike has
i have a reebok rb1000 exercise bike when i adjust the load up the resistance doesnt change. can anyone help
Posted on Jan 19, 2010
SOURCE: Convert rpm or revolutions to miles or read odometer correctly
how to convert 1440rpm to revolution
Posted on Mar 05, 2010
maxtreadmill
  • 832 Answers
SOURCE: the digital display
If the display has a gray back ground and black numbers this unit maybe using 2 AA size batteries to operate the console
Posted on Mar 12, 2010
At start up,engine makes clonk noise ,second it starts,
The clunking is most likely the starter/flywheel issue. Loose starter, starter or started bendix damaged or flywheel cracked. The P0137 is a post O2 sensor voltage low. If the sensor has not been changed, probably the sensor has failed.
Apr 05, 2014 | 1999 Chevrolet Silverado 1500
Coolant sensor broken
The BEST way is to replace the sensor. If the connection is loose or comes loose it will tell your cars computer false readings. It will save you problems in the future. Retail parts stores also carry the sensor for less than the dealer most times. Good luck!
Jul 21, 2012 | 1997 Hyundai Sonata
Wont start
starter cog is spinning and not engaging in flywheel , take out starter check for burr on cog .
Mar 22, 2012 | 1996 Jeep Grand Cherokee
Abs and traction control light remain on.brakes were checked and are fine.any suggestions.
Most likely one of the wheel ABS sensors is defective, it makes the vehicle think that one wheel is turning at a different speed to the others which causes issues for both the ABS and the traction control.
Mar 10, 2012 | 2005 Chevrolet Impala
Hi, I am owning a bajaj pulsar 150. digital display meter, head light, brake light and indicator lights r not working. i went to a mechanic and he is saying it is sensor problem which controls all lights...
I think its the internal wiring problem. I too faced the same issue and my mechanic told that the wiring has gone (and indeed it was gone) and once i had rewired everything started working fine.
Jul 28, 2011 | 2007 Bajaj Pulsar 150
Solo44 4 minutes ago My 1999 Chrysler LHS has a serious problem the starter does not spin but it whins when I turn the key. I replaced the starter with a new one and still have the same problem,I replaced...
Looks like an ECU problem,
You should go to your nearest dealer and check/scan and analyze your computer/ecu, some of the sensors might not be working already and need to be replace.
In the issue of starter, if it clicks and the motor of the starter whines up, it means it is working fine, the problem would be the bendix drive/gear can't reach the flywheel to start the engine.
My suggestion would be to bring that car to your dealer to check the ecu/computer and if the starter assembly is for your car model( sounds like its not for your car).
Hope that solves part of your problem!
Thanks for using Fixya!
Dec 12, 2010 | 1999 Chrysler LHS
Setting the cps
crank positioner is fixed ,but had a similar problem with a rover 45 ,put another engine in and done the same thing,the flywheel shapes on the inside of the flywheel engine side were different ,just slightly ,changed flywheel and away it run like a dream .the shapes i mean were the bits that sense the pick up sensor
Dec 15, 2009 | 2002 Jeep Grand Cherokee
Crankshaft Sensor
what ever u mounted fom the old flywheel was not a magnet....the magnet is internal to the cranksensor and the flywheel slots trigger the sensor....whatever you attached maybe causing this code
Oct 14, 2008 | 1998 Dodge Ram 1500 4WD
Exercise & Fitness Logo
180 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
