Question about Dryers
Samsung electric dryer keeps burning up thermal cut-off thermostat
Had this dryer for a few years. Two weeks ago suddenly stopped heating (few weeks before that the outlet outside the house was clogged up-removed and dryer functioned for another month or two). Disassembled front panel, cleaned the lint out and checked the thermostats/heating element. The thermal cut-off thermostat (on the heating box) had no continuity-replaced it, dryer functioned for two loads then no heat again. Again the thermal cut-off thermostat had no continuity-Thinking maybe the high limit thermostat was welded closed I replaced both the thermal cut-off and the high limit thermostat. Dryer worked again for one load and the thermal cut-off thermostat failed. Now, I have disassembled the dryer and tested every thermostat. There is a thermal cut-off thermostat and thermistor (going into the drum) in addition to the 2 thermostats on the heating box. The thermostat going into the drum has continuity(manual states <1 ohm), the thermistor reads about 13K ohms at room temperature (manual from manufacturer says 10K ohms at 77F), also tested the moisture sensor, that does not have continuity at the sensor, the manual says approx infinite ohms without laundry, 190 ohms with wet clothes. Now I have also disconnected the exhaust line inside the house and although there is lint on the sides there is no blockage or major restriction and there was good flow coming out of the house the first time I changed the thermostat. I am perplexed why this keeps burning up the the thermal cut-off thermostat. In fact this last time it even melted a portion of the plastic thermostat near the prong and part of the wire as well. Any help would be greatly appreciated.
4 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: Whirlpool gas dryer model WGD9200SQ0,
Hello & Welcome to FixYa
The problem is with the door switch or the flame sensor that is bad and needs replacement, you can test both these parts and let me know the result. Please get back to me if you have any other questions.
Kevin
Posted on Jul 19, 2011
oldTech2332
  • 2341 Answers
SOURCE: electric dryer spins no heat, replaced heater
in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
Posted on Jul 20, 2011
Jahn27
  • 1554 Answers
SOURCE: No heat in a Profile
The thermistor at the back of the dryer is the inlet thermistor and it has a normal resistance of around 2270 ohm at room temperature, not zero. A zero resistance means the inlet thermistor is shorted and the control board sees it as an overheating condition and does not activate the heater relay. Replace the inlet thermistor with part number WE04X10111.
The thermistor on the blower housing is the outlet thermistor and it has a normal resistance of around 10000 ohm at room temperature. The heating is good at 17 ohms and inlet safety thermostat and the high-limit thermostat on the heater housing and the outlet safety thermostat on the blower housing must all have continuity.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 22, 2011
Dryer spns but there is no heat
probally the heeting element
Mar 10, 2015 | Samsung Dryers
My electric dryer doesn&#39;t heat up
Whats the model number and brand.
Fix should be straight forward.
a) One of your safety switches is burned out. Example Thermal fuse, Safety thermostat etc. Or Thermistor problem. Cheap fix.
b) or your Heating element is burned out. Mid price range repair.
c) or computer board relay problem. Repair could go up to $ 300/= plus with parts and repair labor.
From Service experience.... If it is SAMSUNG most likely the heating element. If is Whirlpool or Maytag then Thermal fuse or Safety cut off.
If the failure is due to safety switch failure, then after replacing the safety switch you have to check your lint exhaust line to make sure the line is clear. It may be blocked and thats why the safety has burned out. Though not always.
Sep 26, 2014 | Kenmore Elite HE4 Electric Dryer
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
I am not familiar with the model.
That the thermostat keeps failing, due presumably to overheated/burned contacts does indicate the element is drawing too much current. I can think of no other reason to explain your experience except possibly there is excessive arcing at the contacts as they open and close. The addition of a suppressor capacitor might help but the big question to be answered is why is there too much current or excessive arcing...
I can only suggest you thoroughly examine the heating element looking for breaks and accidental short circuits between the coils of the element or connecting wires.
Feb 28, 2017 | Dryers
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Dryer fuse and thermistor continue to burn out
how about bypassing the thermistor,you really only need the heater box fuse and high temp. cut out thermostat-mike
Jul 16, 2009 | Kenmore Dryers
Dryers Logo
116 people viewed this question
Top Dryers Experts
