Question about Tevion Televison & Video
I Have a tevion 48405 digital set top box that does not respond to remote control and will not repond to manual control new batteries fitted but still no picture or sound,the green light is on all the
Set top box is dead apart from green light on
SOURCE: TEAC dvb420 set top box
Sorry guys, have checked on other forums and unless it is still under warranty, or you are good with electronics, it is not worth fixing. Apparently it is a problem with the chip and capacitors on the board. I opened up my STB after fining this out and found heat stress marks all around the chip. Result : Its dead!
Posted on May 14, 2008
SOURCE: sound to image out of sync
same problem here sounds common, going to change it for different make.
Posted on Oct 30, 2008
SOURCE: Remote control for teac set top box HDB842 will not work .
I had the same problem and tried new batteries with no success until I had a close look at the terminals. One of the +ve terminals was rusted (Ithink a drink spill, hastilly wiped off). After restoring this terminal everything is now OK. Hope this helps.
Posted on Jun 01, 2009
SOURCE: I have a set top box GUDSTB2000 but I can't get sound from TV
hi had same problem with my digi-box
simply unplug box from mains & re-connect.
it worked for me.
cheers russell
Posted on Oct 24, 2009
Testimonial: "thanks for the suggestion. However, I've had to replace the Grundig set top box, disappointingly, with another make and it works perfectly. Thanks, "
SOURCE: Universal Remote Control code for Strong STB
i need the code of strong reciver for remote control
Posted on Apr 11, 2010
Where can I buy a remote control for my Tevion DVD recorder model DD1018 please?
GenuineCopies.tv - Replacement remote control for Tevion MD80857
www.genuinecopies.tv/remotes/brands/tevion/md80857.htm
Tevion MD80857. (Our category: DVD/Blu-ray Player Remote). Replacement Remote Control. No setup is required. All you need to do is to insert two batteries and it is ready to use. Long battery life; remote goes into very low power sleep mode when not in use. This remote works on the Tevion MD80857 only. You will be ... Missing: dd1018
televison & video can't find the component code for my tevion dvd ...
https://www.pete-maravich.com/q1029833_find_component_code_tevion_dvd_recor... Can't find the component code for my Tevion dvd recorder DD 1018. I want to replace the badly designed remote that came with this DVD recorder with the Sony universal remote RM-V210T but I can't find the component code anywhere. 4.0 stars ...
Remote Controls for Tevion
www.remote-controls-shop.com/catalogue/Tevion Remote Controls for Tevion. If you're looking for remote controls for Tevion, then you've come to the right place! We sell a wide range of remote controls for Tevion including both manufacturer's genuine original remotes and cost-effective replacements. Our database covers 253 models or parts for Tevion and our ...Missing: dd1018
Tevion DVD recorder DD1018 replacement remote Google Search
Mar 10, 2018 | Tevion Televison & Video
Sky remote code for tevion tv model 43858
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 16, 2012 | Tevion Televison & Video
Codes for urc22b 8 in 1 tv remote for tevion tv
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Jul 23, 2012 | Tevion Televison & Video
Need instructions and manual for Tevion 8 in one control
u need to get a universal remote and a code book,then your most likely wont have any more problems
Feb 21, 2009 | Philips REM110 Remote Control
Tevion TV set top box remote control code
Tevion is made by Medion..
The only code I find for them is 191
Good luck..
Jan 01, 2009 | GE JASRM84964 Remote Control
Suspect controller to Tevion Set Top Box.Batteries replaced. How can I tell if is the STB or controller without purchasing another?
Opened up the remote controll to find corrosion on the the positve contact within the unit.A rub with emery cloth fixed the problem.
Jul 24, 2008 | Televison & Video
Omega urc-08 device codes
Original link no longer working. Found this: http://files.remotecentral.com/download/220/urc08-manual.zip.html
Comment if it's wrong one.
Nov 22, 2007 | Televison & Video
Televison & Video Logo
73 people viewed this question
Top Tevion Televison & Video Experts
shaun taylor
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Are you a Tevion Televison and Video Expert? Answer questions, earn points and help others
