Question about Hobart Dishwashers
Commercial dishwasher model FT900 BD SERIAL NO. 27-1169-395
COMMERCIAL DISHWASHER 892045
SOURCE: hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Posted on Oct 13, 2008
  • 258 Answers
SOURCE: door spring on dishwasher broke
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
Posted on Jan 15, 2009
  • 6 Answers
SOURCE: pressure release keeps draining hot water
The 1/2" drain line you are referring to is probably the 3/4" line from the booster heater located to the left of the pump motor. The temperature/pressure relief valve is bad.
The booster heater could be overheating (bad thermostat), or you may not have an expansion tank on your building hot water system. The heating and explanding water in the booster has no where to expand to, causing a pressure spike high enough to pop the valve.
First, change the valve. I use a heavier-duty Watts XL40 valve, I purchase them from International Commercial Supply or Johnstone. Even if there is a cause for them to leak, once they start leaking they need to be replaced.
Once the new valve is in, power up and test the unit. Power up and fill the unit, then let the booster recover until it cycles off. Run a cycle, and check your rinse temperature. I like to see 190-192 degrees. If it went higher than 195 I'd turn the thermostat down. If it didn't shut off at all, and the relief blew, time to replace the thermostats in the booster heater.
Posted on Sep 12, 2009
  • 55 Answers
SOURCE: insinger commercial dishwasher ...water keeps
bad fill diaphram replace fill diaphram and you will be fine
Posted on Sep 27, 2009
  • 110 Answers
SOURCE: require installation instructions, and parts
wm5h many parts are obsolete for that dishwasher
Posted on Jan 09, 2010
Why does my Electrolux commercial dishwasher come up with error code A1?
Check Water supply (valve, filter, pressure)
Check that the overflow pipe is inserted
Jul 12, 2016 | Electrolux commercial undercounter...
How do I disassemble the pump?
What is the model of your dishwasher?
Jun 27, 2015 | Hobart Lx30h Commercial Dishwasher
How to fix a commercial dishwasher
Simply determine what is not working, diagnose the problem, make correction or replace defective part and test operation. This is the best answer possible as there is no information as to what is wrong with the machine in your post.
Dec 12, 2012 | Hobart C44a Commercial Dishwasher
Dishwashers Logo
89 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
