Question about Microsoft Xbox 360 Console
Well i can get my tray opened and closed but it wont read the disc. and the belt came out and its broken
    Problem Solver:
  • 14 Answers
Look around and buy a new dvd drive
Posted on Jan 03, 2009
CD Tray could not be open, and the disc cannot be played.
Sometimes they are driven by a rubber belt that has come off or broken. Just have look inside and see. If it is the belt and you need a new one just measure the diameter of the belt in MM and put "XX MM drive belt" into google and get the size close to your measurement.
Dec 16, 2012 | Audio Players & Recorders
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
I have an RC100H that keeps opening the DVD/CD tray as if it does not read the disc. Even if I have no disc in it the tray opns and stops. The only way to keep the DVD Tray closed it to hit the close...
eject belt propably worn out, does not close lid proper - so ejects back. change of belt solves problem.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 21, 2011 | LG RC199H DVD Recorder/VCR
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
As soon as i turn on my 360 the disk tray light wont stop blinking and disks wont read
Listen close and see if you hear the tray motor running. If you do then, most likely, the belt and pulleys that move the disk tray are dirty. Which might also explain not being able to read disks. Here's what to do: Pull the face plate off of the 360. This will NOT void your warranty. Beneath the disc tray (look under and "into" the tray) you should see a gear wheel on your left side. Push eject. Use a toothpick (or similar object) to turn that gear from left to right. Keep turning and the tray should pop open. Unplug (WITHOUT turning off) the 360. Pull the disk tray to full extention and look through the slot in the center of it. You'll see the belt and pulleys. Tweeze the belt out small pulley first clean the belt & pullies w/alcohol. Put belt on big pulley first. Then run a lens cleaner disk when you get it opening again.
Nov 24, 2009 | Microsoft Xbox 360 Console
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
Sony DVD Player keep ejecting CD/DVD tray - not detecting any disc.
if it keeps on opening up and wont close then the tray dectection switch is broken.....you need to get a new player.
or ifs its not reading the disc the laser mech is probably stuffed....time for a new one!
Aug 13, 2009 | Datel Max Media Manager Pro for Sony PSP
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Mike Neath
Mike Neath
Jonathon summesfield
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
