Buy eltax tweeter item3080 spec hd-200wfp
Want to buy
2 Suggested Answers
tech240
  • 169 Answers
SOURCE: i need a tweeter or the specs for a hi freq.
Try this link
http://www.jblpro.com/pages/recording/4400.htm#4412A
Thanks for using FixYa, I hope this helps.
Posted on Oct 23, 2009
I have a replacement tweeter for an Eltax Liberty 5+ floorstanding speaker. I have removed the screws that hold the old tweet in place but can't seem to remove it? Any tips please?
Hi, The hole that was cut for the tweeter is holding the magnet. It was tight going in. And hard to get out. Take a flat screwdriver and pry up one of the edges a little. Then go to opposite side and pry up a little bit. You may need to put something in the gap of the first side you pry up so it doesn't go back in. Once you have both sides up a little bit. You should be able to grab ahold of it with your fingers and remove it. May have to move it back and forth .
Apr 02, 2015 | Eltax Audio Players & Recorders
Hey i need help. I have a Boss amp and i wonder if i will be able to use these tweeters i want to buy
On the Boss amp, you will need to use rated ohm speakers for each channel. Cross reference the amp for detailed specs.
May 28, 2014 | Car Audio & Video
Hi I have a eltax impact 10 and when I turn it on and put music on it cuts straight out power still on just sub stops working can any 1 help into diagnosing the problem ? Cant afford a new 1 and u can't...
Test the voice coil of the sub with a digital multi-meter. Make sure it is within spec. They are usually 4 or 8 ohms. If OK, the plate amp is shot. They are not worth repairing. Good replacement amps can be bought from Parts Express for as little as $100 or less.
Nov 25, 2013 | Car Audio & Video
Eltax Atomic A-8 A8 Active Subwoofer i have a burnt out power transformer
Power transformers are safety parts and should only be replaced by the same type or one specified by Eltax the maker. You should contact them for the spare parts department or the place that stocks them.
Jun 01, 2013 | Audio Players & Recorders
How to setup an eltax surround system? what exact place do I put them (also behind me)? It contains 4 speakers, 1 sub-w, and 1"tweeter/high range" to put on your tv. I thank You sincerely!
Well, that is pretty dependent on the room size and seating position. Ideally the center channel should be directly under the TV. This is where 90% of the dialog will come from. The two tall speakers should then be placed adjacent to the TV, preferably a couple of feet away. The smaller surround sound speakers should be approximately ear level, to slightly above and behind the viewer. The surround speakers are bipolar, so they will radiate sound out of each side, therefore you do not need to "angle' them towards the listener. The sub woofer doesn't really matter, the bass frequencies are non-directional. I like to hide it under a table or something like that.
Some new receivers have built in surround set up programs that will send a test signal to each speaker and "listen" then adjust the delay and volume accordingly. Without that it will take some trial and error to get any system dialed into the perfect settings. Then what may be ideal for one specific location will sometimes not sound as good from another in the same room.
Good Luck.
Dec 24, 2010 | Eltax Chroma 5-Pack System
I need a tweeter or the specs for a hi freq.
Try this link
Oct 22, 2009 | Audio Players & Recorders
Can't find specs/maker of klh 900b tweeter
KLH 900B tweeter specifications: 6 ohm, 40 watts. By the way, KLH's QC for speakers could be improved. One of my 900B tweeters quit because the spacing for the voice coil was way off reasonable tolerance and the body of the speaker coil base pillar (ie: magnitized part) was off-center - and cauesd the coil to ware and short. I contacted KLH but they did not respond.
Sep 19, 2009 | KLH 900B Main / Stereo Speaker
No sound from top speaker
Yes Eltax will sell you a replacement part. THey also sell the woofer/driver as well. Changing either is simple. You will need a Torx screwdriver to unattatch the driver from the box. Then just pull it out, and attatch the connectors to the new tweeter. Make sure you get the wiring right for polarity. Ie look at the writing on the back of the tweeter and keep the wires going to the same connections on the new one. Screw it back in...and you are done. I have a pair of these as well, and have just done the same replacing both woofers that had been pushed in my my niece and her inquisitive hands !
May 17, 2009 | Eltax Liberty 5+ Main / Stereo Speaker
Eltax millenium 500 speaker problem
Some high end speakers have a fuse to protect the tweeter (treble). Reverse the speakers. Does the problem follow the suspected speaker? If so, the defect is most likely on the crossover inside the speaker.
What do you mean by best place to locate parts?
Apr 16, 2009 | Eltax Millennium 500 Speaker
Eltax speaker problems
I agree, NE Speaker is the BEST repair speaker shop in the eastern half of the USA. I have an EV 12" speaker re-built there and its better than it was before it was blown. Great job NE Speaker!!!
Leo B.
Jun 23, 2008 | Eltax Audio Players & Recorders
103 people viewed this question
 Grubhead
Grubhead
