Question about John Deere Garden
The rod on my John Deere tractor fell off that makes it steer...how do I fix it ?
John Deere GT275, 42", Hydrostatic, 22HP
  • Teresa Firth Oct 29, 2012
    Thanks for the info....it was the ball joint. I bought a new one to replace it.
  • 80 Answers
Sounds like the ball joint on the steering link is worn and dropped out some models have replaceable ball joints and some you must replace the entire steering rod in either case check all ball joints for wear and replace as they are worn as well
Posted on Oct 26, 2012
5 Suggested Answers
  • 130 Answers
SOURCE: john deere lawn tractor has a miss or a pop sound
need to check valve clearence get a manual for spec
Posted on Jul 18, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
mickey813
  • 472 Answers
SOURCE: John Deere CR125 hydrostatic mower, engine runs
sounds like you have carb problems
Posted on Oct 15, 2009
  • 402 Answers
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Posted on Jun 02, 2010
Do you have a diagram of the parts to fix alignment
Here is a link to the John Deere parts site. Type in D130 in the model box, you will also need your serial number. Hope this helps.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Jan 30, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Front end out of alignment how do i fix
Paul it appears your machines steering components are not adjustable, as normal tie rods are. So that means you have to replace steering parts that are worn or try and repair bent steering parts. You could have your steering links made adjustable at a machine shop. below is your manual,
press the helpful button.
http://www.homedepot.com/catalog/pdfimages/fd/fd904936-46bd-471e-9536-7c3ca3698e81.pdf
HOW DO I ALIGN THE FRONT WEELS ON A D130
loosen up tie rod unhook tie rod from spindele turn tie rod in hook tie up to spindle see if straight if not repeat till straight make sure tie rod end is not bad replace if is make sure spindle not bent replace if it is
Sep 04, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
What all transmissions will fit a john deere L118 model
All L series tractors transaxles should fit. What is the problem with current axle.
Oct 08, 2013 | John Deere 22HP Hydrostatic 42" Riding...
My john deere riding mower shuts off when it getshot acts like itss not getting fuel
check the fuel cap and make sure the vent hole is cleared and free of any debris
Jul 03, 2011 | John Deere 22HP Hydrostatic 42" Riding...
My John deere l118 riding mower goes slower and slower. suggestions please
Firstly remove the battery and battery tray and clean all grass and debris from around the hydrostatic drive and cooling fan. Secondly check the drive belt idler pulley, arm and spring for free travel. Hope this helps, regards Phil.
Jun 18, 2011 | John Deere 22HP Hydrostatic 42" Riding...
How do I adjust valve rods and what's the clearances ? Model325 John deere lawn tractor.
Hi I'm Dane, and I'm going to help you solve you problem. Glad to finally get this answered for you. The piston should be set to top dead center on the compression stroke. Adjust the valves when cold to .004 Intake and .006 Exhaust. Torque spec is 61" lb .If you found this reply helpful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Dec 06, 2010 | John Deere 22HP VTwin Hydrostatic 42"...
John deere 300 garden tractor hydrostatic drive will not work
Jun 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
363 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
