Question about Gateway Computers & Internet
How can I hook up my Sanyo T.V. to my laptop?
I have bought a HD cable but not sure where to connect it to the T.V. there's a lot of places but one end doesnt look like a computer connection and one end does.
  • 2,878 Answers
You need a cable or adapter that conforms to the ports. Most common are VGA, DVI and HDMI. Then set the TV to that input. Some laptops also have monitor swapping or both.
Posted on Oct 26, 2012
rickyostrom
  • 270 Answers
SOURCE: Dell Inspiron 1525 - Firewire not working
It may be the communication setup.
You might need to set within the Camera PTP protocol.
The WD drive specs out a 6 pin connector, not a 4 pin.
Posted on Nov 17, 2008
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Posted on Feb 17, 2009
  • 46 Answers
SOURCE: compaq nc6000 laptop wireless connection
Wireless connection? If so, make sure the wireless device is enabled on the newer one. If it's a red light, the wireless device may be faulty. If so, just get an external USB wireless device and use that. Check to see that the same lights are on with both PCs.
Posted on Mar 04, 2009
  • 4 Answers
SOURCE: Laptop won't connect to internet
Once connected to the ethernet cable you might have to press the tiny reset button on the back of either your gateway,router,modem of whichever service you have(Cable,DSL)
Posted on May 27, 2009
tvservice306
  • 458 Answers
SOURCE: i am trying to connect my acer aspire 5100 laptop
try adjust computer viedo for 800x600 60 HZ output
use keyboard Fn key + F6 (use manual ) copy to tv.....
Posted on Nov 19, 2009
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ...
www.fixya.com > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
https://www.youtube.com/watch?v=awwXqdPRkNw
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
www.hivmr.com/db/199a98kjjjjz33k9kzk9p8kdfc1cdfjs
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
Jan 20, 2016 | Sanyo Office Equipment & Supplies
Hi, I have a sky tv link set up in my bedroom to a Samsung tv that works fine, however I have bought a Sanyo tv and the sky doesn't work on this tv??!! Any help would be apreciated
go to menu and find connection settings see if it is cable or air please select cable...
if already done but no change maybe your TV is not hd..select air only..
Mar 06, 2012 | Sanyo Televison & Video
Connect laptop to tv
To connect a laptop with a Sanyo TV, the TV must have VGA cable connection. VGA cable picture
If the TV is not equipped with a VGA cable, it can not be be a laptop and a TV connection.
Jan 07, 2012 | Toshiba Satellite A665-S6086 16-Inch...
We bought a used Philips 42" flatscreen digital TV with no remove and hooked it up to our cable box. It works beautifully but we have not able to reset the screen size using the side buttons and menu...
Yes there is a trick. Usually the cable box and its remote determines the picture's screen size. First off, this television is able to display hd on an hd cable box. Make sure that this cable box is connected with this television the hd way only. It should only be connected to your television with either a component (green,blue,red, white, red) cable OR and hdmi cable. The coax cable should not be used to connect the cable box to the television if you have an hd cable box. Next make sure the television is on the proper input/source to display the cable box in hd.
Now if all of this has already been done, look for the hd zoom # button on your cable remote. It is usually towards the bottom. When you press it you change the screen size. You can buy a philips remote-the original one for your television at http://www.replacementremotes.com if you need the wide/stretch/zoom/viewmode button to further adjust your picture size.
Jul 16, 2011 | Televison & Video
I just bought a sanyo dp42841. I used to have the same tv in a smaller size. The first tv was hooked up to the cable and worked fine. When I attached the same cable to the new tv it's not able to find...
Be sure your cable is hooked up good and if you did not auto scan you must do this (auto scan) Found in the menu setup. Use the remote and press menu and it is usually found easily. Highlight the auto scan and start the scan usually by pressing volume +
May 20, 2011 | Sanyo 42 in. LCD TV
How can i hook up a nintendo wii to my 50 inch sanyo plasma t.v and keep my digital cable hooked up at the same time?
I just took a look at the back of your TV and I know exactly what your problem is. First, you need to understand that digital cable is not HD cable necessarily and standard digital cable has analog outputs. Now, since you're concern is about not being able to keep your Wii connected to your TV without disconnecting your cable box, what you are telling me is that with the numerous numbers of input jacks on the back of your set (and the fact that the Wii comes standard with a red/white/yellow Analog Composite cable) you are using the only set of Analog Composite inputs (that also includes the S-Composite input) on your television set to connect your devices. Now, if you actually have an HD box, then you are not using the correct connections and cables and your beautiful 1080p Resolution High Definition television is displaying everything on cable at 480i Resolution, Standard Definition, even the HD channels. Analog connections are incapable of displaying in HD.
Now, I don't know about you, but when I put down my chunk of change and upgraded to HD, I wanted to make darn well sure that I didn't spend all that money to watch it in SD. Of course, that's tongue and cheek because I know you wanted the same thing and I'm going to walk you through the process of solving your problem and getting you the best picture possible out of your TV.
So the first order of business is to make sure that you have an HD box and if you don't you need to contact your cable provider and swap it out. Next you need to get yourself an HDMI cable for about $3. DO NOT waste your money on one in a store and do not believe any salesperson that tells you that the expensive ones are better than the cheap ones. They aren't and this is the biggest lie in consumer electronics perpetrated primarily by Monster Cable. Order it from Monoprice, as they are the best and cheapest. 6 feet is the standard.
http://www.monoprice.com/products/search.asp?keyword=hdmi+cable&x=0&y=0
An HDMI cable is one cable and all you need to do to connect it is put one end in the HDMI 1 input on the back of your TV and the other end into the cable box. It handles both the audio and video signals and your HD cable box should automatically detect it for video and audio. If by chance it doesn't detect the audio, go into the settings menu of the cable box and choose the audio sub-menu and set it to HDMI-out (these options might be under the heading "digital audio").
You'll also want to go into the video settings of your HD cable box and set the output resolution to only display one resolution (it will probably have several selected by default). Choose 720p or 1080i (your preference) as these are the only HD formats cable television broadcasts in. I have mine set to 1080i and the reason you do this is because not all channels are in the same resolution on digital and HD cable and what will happen is that your TV will have to reset its resolution every time you change channels and the resolutions change. This transition can take up to 30 seconds as you're sitting there staring at a black screen. By setting the resolution on your HD cable box to display only one of the HD resolutions, your HD box will simply upconvert the other resolutions automatically. I say choose between 1080i or 720p because not all cable providers broadcast in 1080i, using 720p exclusively so the 1080i setting is unnecessary.
Last thing about your display regarding HD cable: Your HD cable will display television programs in both the 4:3 (standard) and 16:9 (widescreen) formats. When the program is in 4:3, the image will not fill the entire display showing black bars on the left and right sides of the image. Plasma TV's are susceptible to what is called screen burn-in (or image retention or as Sanyo calls it, "after-image"). What this means is that if static images stay on the screen for too long, it will actually stay in the screen after you've changed the channel and it can be permanent and this damage is NOT covered by your manufacturer's warranty. Your TV has a feature to fix this (refer to your manual, near the end) if the "burn-in" is not too extreme, however the best way to avoid screen burn-in is to prevent from happening to begin with. While the TV is displaying a 4:3 program, the point where the image ends and the black bars (lack of image, technically) will burn-in. To avoid screen burn-in, you should change the format of the image to fill the screen via either your cable box (your cable remote will have either a Zoom key or a Picture Size key) or on the TV by pressing the PIX key on the lower left hand corner of your TV remote until you get the desired image. Use the option that zooms in, and not the option that stretches and distort the image. HDMI Cable captainhawk1_8.jpg
So now you have the Analog Composite inputs free to use for your Wii, however, I'm going to give you another alternative that will increase the quality of your picture when using your Wii. The Wii has the ability to use Component Video Cables for its video signal sent to your TV. Your TV has two Component Video Input Jacks (VIDEO 2 and VIDEO 3) and the are indicated by their red, blue, and green color. You'll still need to use the analog red and white audio connections when using the Component Video inputs but for this setup, they are right to the left of them.
Now, of course, Nintendo does make this cable but their's costs $20 and again, you can go right over to Monoprice when you get your HDMI cable and get it for less than $3 and like the Nintendo cable, it comes with the audio cables integrated. I have this cable myself and it makes an amazing difference.
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10830&cs_id=1083007&p_id=5689&seq=1&format=2
Your TV will automatically detect both the HDMI connection and the Component Video connection so it will not require any setting up.
For more information refer to your manual, here:
http://us.sanyo.com/dynamic/product/Downloads/DP50747_Manual-31187309.pdf
May 06, 2011 | Sanyo DP50747 50 in. Plasma TV
I just hooked my wii & all we get is black & white
I had the same problem. Instead of going directly into the TV, I tried plugging the component cable into the auxiliary jack in my digital cable box and that seemed to fix it. Works great now.
Jul 19, 2010 | Nintendo Wii Console
What type of HDMI cable do I need to connect my DVD player to my HD Sanyo TV?
Make sure DVD player and TV have HDMI ports at back to hook with HDMI cable.
HDMI cable has standard plugs on both ends and its length can be different like 3 feet, 6 feet or 10 feet. Click HERE to buy required length HDMI cable.
Oct 23, 2009 | Philips Televison & Video
My picture is not good. I'm hooked up to digital
to get best picture and sound you need to use HDMI connection. This is normally if you have a HD cable box. If you don't have a HD box, use the coax connection directly from the cable line. On your TV, hit the menu button, use the arrow up/down to select manual channel search, select cable and hit enter. this will scan all the digital and analog channels.
Jun 16, 2009 | Sanyo Televison & Video
How do I get rid of error message across top of TV that reads "Your television cannot support HDCP video over your high definition connection (H1001)".
Use component cables instead of hdmi cables. I know this isn't the best solution, but HDCP is not used over component and the video quality is just about as good.
Jun 04, 2009 | Westinghouse SK-26H240S Television
Computers & Internet Logo
295 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
