Question about Maytag Clothes Washer Dispenser Bezel 22003273
May tag washer Neptune door won't open
    Sergeant:
    Champion:
  • 249 Answers
What is your model number is then we can get started then
Posted on Jan 14, 2013
Unlocking a may tag door washer
Fuse open ... must meter all the fuses in the back. Use an ohm meter.
Jun 02, 2016 | Maytag MAH6700AWW Neptune Front-Load...
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
The washer was starting spin cycle. It stopped & started huming. The door won't unlock. It has water in it. unplugging hasn't changed anything.
If it has water in it it may not unlock the door, it depends on what type of door lock is fiited as it may be a pressure type. If you can get the outlet hose out and lower it below the level of the drum to drain the water that is in it then the door may open oncethe pressure is gone.
Dec 27, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
Why won't my maytag neptune front loading washer will not start?
Check out the door switch to make sure that it closes when you latch the front door. If it does not close the machine will be inoperative - safety measure.
Sep 19, 2017 | Maytag Neptune MAH5500B Front Load Washer
I own a maytag neptune washing machine. It was working o.k. and suddenly it won't start. I push the start button and it buzzes and shows a message that says,"It appears the door was not opened...
Hi Debi:
First I suggest to try unplugging the unit for 60 seconds to reset the control board. If that doesn't work then open the dispenser and remove the softner and bleach container. There is a cord near the front you can pull to open the door lock. If you still have issues with your door lock after manually opening the door, you will need to order and replace the door latch assembly.
Also I could bet you need to replace your door latch assembly. Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 06, 2011 | Maytag Neptune MAH7500A Front Load Washer
My door won't latch on Maytag Neptune. What parts
I do not want to take away from what another says...however i seriously have doubts that replaing the door panels will fix that and i would replace the door latch thats fits into the cabinet if i were you
Gene
Aug 19, 2011 | Maytag Neptune MAH6500A Front Load Washer
Maytag Clothes Washer Dispenser Bezel 22003273 Logo
74 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
