Question about Canon imageRUNNER 2870 Copier
May canon ir 2870 eror code below E000732-0010
Sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Posted on Nov 18, 2012
  • Anonymous May 05, 2016
    e0225 becouse ccd error visit myblog for full explain, pesancopy.blogspot.co.id
canontech
  • 1219 Answers
SOURCE: error code 19
You have waste toner full!
Remove the drum, on top of drum there is cork, remove cork and vacume all the waste toner out.
Posted on Jun 02, 2010
KyoDoc
  • 38 Answers
SOURCE: IR 2870
The waste toner container is full. the front cover of the machine (the one with the Canon logo on it) must be removed. behind you will see a big white plastic bottle. Remove the bottle, empty the contents into the bin, wipe it off, and refit all removed parts. Finally restart the copier.
Posted on Sep 24, 2008
SOURCE: my canon copier ir 2016j give an eror report code
- check the connector of the fixing film sensor.
- replace the fixing film sensor.
- check that the fixing film is not broken or out of place
Posted on Nov 25, 2009
canontech
  • 1219 Answers
SOURCE: I replaced the black tonner on my Canon ir 3320n & this eror sho
try to set the toner a few times more, this error code is developer trouble.So it could be that toner isnt recognized, not properly inserted, or you have some tape leftovers on toner, or you have broken developer unit, or ...
Posted on May 06, 2010
SOURCE: Sir I have Canon IR
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Posted on Jun 09, 2011
How to repair error code E225
Code E225-0001 Description The light intensity of the CIS is faulty.
During shading operation, the intensity is below a specific level. Remedy Disconnect and then connect the flexible cable. Replace the following as necessary: flexible cable, CIS, reader controller PCB.
Aug 08, 2015 | Canon IR 2870 Digital Copier RECONDITIONED
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
Aug 04, 2014 | Canon Crtdg, gpr15, ir 2270/2870, bk
E000716-0010
The error you are giving isn't a toner error. It relates to a loss of communication with the pedestal. Canon's service manual says to check the cable leading down to the pedestal. If still properly seated, replace the DC Controller Board or Pedestal Control Board.
Reference: Canon Service Manual Page 694. You may be able to locate the manual by a Google search. Search for "Canon iR4570/3570, 2870/2270 Series Service Manual"
Dec 08, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
2870 canon copier machine showing error code E000024-0001
remove your doveloper unit and check sensor, it is luse or re fix again ,........
Sep 24, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Eror code e00732-0010
check the cable that connects the scanner to the copier body
it sometimes gets broken you can wiggle it and reboot the device
thats the only thing that goes bad for this code
Oct 29, 2012 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Canon ir2870 e000732-0010
your problem might be faulty connection on your DIMM modules.
Take it out and clean the contact area with a brush, place it back and start the machine.
If this dose not solve your problem it means the Reader Controller PCB is faulty and needs replaced.
Error code E000732-0001 on canon imageRunner 3200n
this is a reader board error ... 1st check all connectors on the machine unplug and replug did this just happen or could there be a connector missing, this code usually comes from the connecter that looks like a small parrellel connector on rear going from scanner to right rear side
Dec 24, 2008 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER 2870 Copier Logo
504 people viewed this question
old marine
old marine
