Question about Samsung PS42C91HDX 42 in. Plasma TV
ON AND OFF BY ITSELF
Samsung technician informed that the Main Board BN94-01506A must be replaced. After checking their stock ,Samsung Indonesia informed that this parts had been discontinued. How come ? I just bought this TV two years ago. Please help and advise what to do. Thank you.
  • 4234 Answers
SOURCE: Replace Main Board?
If he is familiar with soldering, try opening up the set and reseating all of the connectors and cables. Then look for poor solder connections and resolder any that appear "bad". Update this with the results.
Dan
Posted on Jul 29, 2008
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
james tv man
  • 88 Answers
SOURCE: My Samsung LN-t4671F LCD TV clicks for about two
You are having another problem with the power board...there are some capacitors which are easily replaced to cave you the cost of the board. If you are technical,I can guide you further,other wise a reputable shop can fix this very reasonably
Posted on Jun 07, 2010
  • 608 Answers
SOURCE: Samsung 46" LCD LN46B650 started showing vertical
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Posted on Dec 10, 2010
Samsung plasma PN51F5300 turns on and off itself
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 28, 2017 | Samsung PN51F5300 51" 1080p Plasma HDTV
Why does my Samsung HT-D5500 blue ray 3D player turn off itself after a few seconds when I turn it on and what is the letter F symbol mean on the display? Thanks in advance
main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 12, 2017 | Samsung Televison & Video
Samsung LNS4692D. Ser # AF0D3CFLA015278: Sound but no picture. Looking for information of age for deciding whether or not to call repairman, or go to the atore for a new one.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 07, 2017 | Samsung Televison & Video
Samsung LN52B530p7f this tv powering on and off by itself sometimes the menu appears without anyone touching it
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Mar 05, 2016 | Samsung Televison & Video
Samsung tv
Feb 26, 2016 | Samsung Televison & Video
Tv powers up. then shuts off by itself after 15 seconds. then restarts by itself...then shuts off after 15 seconds...etc...etc
Jan 08, 2016 | Samsung 50 in. Plasma TV
Why does volume increase by itself to 100 after set has been on 30 minutes?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 25, 2015 | Samsung Televison & Video
My. Samsung tv red. Colour is. Missing Pl. Suggest remedy
Check and replace its main digital processor board. Fault to its main board itself. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 24, 2015 | Samsung Televison & Video
How do I fix my Samsung HD tv from turning on and off by itself?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 14, 2014 | Samsung Televison & Video
My Samsung flat panael shuts itself off continuously
Sep 12, 2014 | Samsung PN Televison & Video
Samsung PS42C91HDX 42 in. Plasma TV Logo
56 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
