Question about Samsung 400CXn 40in Pro Display wTuner OPEN BOX LCD TV
SAMSUNG MONITOR MODEL BE40PSNB CLICKING AND NO PICTURE
PROBLEM IS THE SAME AS THE CAPACITATOR ISSUE WITHE THE SAMSUNG TV'S. THERE IS A CLICKING SOUND AND NOW THE THING HAS SOUND HOWEVER NO PICTURE, COMPLETELY BLACK
SOURCE: No Picture - Samsung LN-S4692D 46in HDTV LCD
I had the same problem and I replaced the t-con board. My t.v. is fixed!!!! I just couldn't see spending another 700.00 dollars for a repair shop to fix it. The t-con board is located at the top of the t.v. once you remove the back cover. Be very careful removing the two plugs at the top of the board which was easy once I figured out how the clips worked. there is a black lever like connection which flips up, then grip with your fingers the tab and slide the tape like wires straight out. The bottom plug is very simple. Also to expose the t-con board you will have to remove a heat shield cover. Once removed there is foil looking tape that needs to be peeled back to expose the board. The board is very sensitive to static electricity so if you have a grounding strap that you can strap to your wrist and ground to the frame while performing your repair. Its best to lay the t.v. face down on the kitchen table with a blanket to protect the screen. Good luck!
Posted on Sep 07, 2008
  • 4090 Answers
SOURCE: Samsung ln t4665f : Power Light On , No Picture : Clicking Sound
there is a soloenoid type switch that fires the TV up this has failoed. its like a neon or fluoresecent tube that has a faulty starter switch light tries and tries but never quite makes it when it does get going it has that purple smear in the tube. that is the simple explanation for your problem. part is about $60 labor is unkinown as i am not in USA but looking at some of the rip off charges I am glad i dont have the bill
Posted on Aug 20, 2009
  • 111 Answers
SOURCE: Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Posted on Feb 04, 2010
  • 21 Answers
SOURCE: Samsung 4061F 40" LCD TV
To all who are having power supply issues: Samsung is now acknowledging a problem with faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem.
Posted on Feb 22, 2010
shalabhnegi
  • 28 Answers
SOURCE: I have a Samsung DLP TV (model HLT5076S). When
this is because the CRT that is the cathode tube ray oscillator is taking time to warm up
Posted on Mar 31, 2011
Samsung ld190 syncmaster
I had exactly the same issue... Opened the frame from the front (use a screwdrive on the join), and then pushed the PCB behind the buttons around (looks like some type of capacitive touch through the plastic). After that, works fine!
May 16, 2013 | Computers & Internet
Samsung syncmaster 275t won't start - what to do?
The Samsung monitor is okay, the problem is a compatability issue between the laptop and monitor. The VGA toDVI is the problem you are converting a analog signal to digital, the signal level degrades when that is attempted. If I understand this the laptop puts out the analog signal "VGA" and the monitor has the DVI input, "digital" The only other suggestion is turn off the laptop screen to see if the monitor will work.
Apr 04, 2012 | Samsung Syncmaster 275T Monitor
The tv s autostore will not retune
i think in your TV...... design ..... is such that once channels are autostored it cannot be retuned ..... so you try this ...... it may work ......... disconnect tv antenna cable ( or local tv channels cable ) from your TV & then click autostoring (auto tunning ) ..... definitely it will scans (search for channels ) ..... but since no cable is connected no channels will get stored ...... but previously autostored channels will get removed ...... so now again connect your antenna cable or local tv cable & then click autostore ...... it will scan for channels .... like this you can retune ....... but remember again you may get same quality of picture which you got earlier ..... if you want better quality of picture you have to use signal amplifier (increases cables signal's strength - then picture quality improves ) .....
Nov 05, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
WHEN I OPEN THE TV THE PICTURE & SOUND IS OK ,BUT AFTER A FEW MINUTES THE PICTURE BECOMES BLACK AND FADE BUT THE SOUNDS IS STILL GOOD .
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Jun 18, 2011 | Televison & Video
Samsung LN55A950 LCD TV 1) Had psychodelic patterns in TV and was told it was a capacitator. I had it repaired and the next day the issue started again. After the TV was on for an hour it went away. ...
I would take it back to where you had it repaired since the problem is still not fixed, it can be the T-CON board is bad.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 09, 2011 | Samsung LN55A950 55 in. LCD TV
LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
Hi my name is Roety,
I can help you with your issue ,
This is most likely a power supply issue
I usually replace the swollen capacitors I can see
A repairman would charge about $300 to replace them for you.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 15, 2009 | Samsung LA40A450 40 in. LCD TV
Samsung TV could not turn on. no sound/no picture
You need to replace your lamp.
remove the lamp and check the number on it, then search for it on google.
the lamp door is in the rear
If I have helped you with your issue please click accept.
I will reply asap
Thanks
Oct 10, 2009 | Televison & Video
TV Has No Picture - Samsung BE40PSNB
If it isn't in warranty, start by trying to email Samsung about your heater here:
www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Dec 31, 2007 | Samsung HP-R4262 42 in. Plasma Television
Samsung 400CXn 40in Pro Display wTuner OPEN BOX LCD TV Logo
52 people viewed this question
Henry  Thomas
Henry Thomas
