Question about HP Photosmart C7180 All-In-One InkJet Printer
CAN I REMOVE/REPLACE PRINTHEAD FOR PHOTOSMART C7180?
THE ONLINE VIDEO SEEMS TO HAVE A LEVER TO RELEASE THE PRINTHEAD - NOT VISIBLE ON MY PRINTER.
  • rclf2r1
    rclf2r1 Oct 27, 2012
    The entire works of the printer is covered. There are several tiny screws securing it. HP does have a printhead assembly for $36 plus shipping but recommended I get a new printer.
  • Anonymous May 08, 2015
    There is a video on You-tube about removing and cleaning the printhead from a similar HP all in one. This information is relevant to the HP C7180, (in spite of what HP tech support might tell you, since HPs solution is to get a new all in one, instead of them trying to solve the problem).
    Scholar:
    New Friend:
  • 43 Answers
No printheads are not removable in photosmart c7180 , thats why its not visible.. the printhead and the ink cartridge are attached.
Posted on Nov 08, 2013
3 Suggested Answers
  • 73 Answers
SOURCE: My Photosmart C6380 printer display
Hi There,
Please follow the below link :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&cc=us&lc=en&dlc=en&product=3560280&tmp_track_link=ot_search#N48
Hope this resolves your issue
Thanks
Enjoy and Cheers !!!!
Please take time to vote for me if this solution resolves your issue..
Posted on Nov 01, 2010
nonontech
  • 4737 Answers
SOURCE: Hp photosmart c7180 will not
I hope you've already tried all the basic steps including cleaning the cartridge and the nozzle (Click here for instructions)
Have you tried with another cartridge? If not, that should be done before you troubleshoot with another method. Otherwise you'll not be able to find out what exactly is the cause, the cartridge or the printer or the driver.
If the same problem persists with the new cartridge, then uninstall printer's driver from your computer and reinstall it. Try printing again.
After driver, your next step will be cleaning the machine. Open this page (click here) and follow the "Step Two".
Let me know the result.
All the best.
Posted on Nov 29, 2010
Hp 7180 foutcode 0xc 18a0201
http://h30434.www3.hp.com/t5/Ink-Toner-Cartridge-Printhead-Issues/Printer-Ink-System-Failure-on-Photosmart-C7180-with-a-MAC/td-p/1220499
Feb 11, 2015 | HP Photosmart C7180 All-In-One InkJet...
How to remove printhead ?
Printhead is typically part of the ink cart on HP printers. Replace ink cart, get a new printhead.
Sep 01, 2014 | HP Photosmart C7180 All-In-One InkJet...
C7180 magenta not working
1. try with a different set of magent ink cartridge.
2. Unplug the power chord from the back of the printer without turning the product off.. then press and hold down the power button for 30 sec. then plug in the power chord..
try printing or continue with the below steps
3. remove the magent ink and then clean it with a lint free cloth the copper contacts.
4. put it back in and try printing
5. do a reset on the printer : Disconnect the power cord from the back of the product.Wait for 20 seconds, and then press and hold # and 6 on the product Control Panel. Connect the power cord to the back of the product and then release the buttons when the product turns on.The product resets to factory defaults.
Check if it works.
6. Then what you can do is on the control panel of the printer press the Setup button >> go to Tools >> Clean cartridge >> OK
7. Again go to Setup >> Tools >> Align printhead >. ok
check if the works or not.. or else service the printer.
Nov 25, 2012 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 printer with clogged print head.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 30, 2012 | HP Photosmart C7180 All-In-One InkJet...
Photosmart C7180 - light magenta and magenta not printing. I've cleaned the heads and aligned the printer. The light magenta is printing when I did the 'Align Printer'. I also completed the 'Restore...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Dec 23, 2010 | HP Photosmart C7180 All-In-One InkJet...
INK CARTRIDGES ARE LEAKING IN HP PHOTOSMART PRINTER
Follow the instructions below to replace the printheads in the All-in-One product.
Video of replacing the printhead
The following video demonstrates how to replace the cartridges and the printhead. You do not necessarily need to replace the cartridges. Simply refer to the video for replacing the printhead, and then stop the video.
Aug 23, 2010 | HP Photosmart C7180 All-In-One InkJet...
Error:oxc18a0206
- Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
1. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit.
Dec 16, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 All-In-One InkJet Printer Logo
180 people viewed this question
Seeker5211
Seeker5211
