Question about Cell Phones
My phone is restarting after welcome screen. i cant update it cause i cant set the usb mode to pc suite and i cant restore settings. i tried nokia sotware updater, jaf nothing works they cant detect p
Problem occurs after i deleted some apps, or i just dont know,
  • fcord
    fcord Oct 25, 2012
    I already tried to use my phone in nokia suite or software updater. software updater cant detedct my phone because icant select pc suite mode because after welcome screen the phone restarts. while the nokia suite detects the phone even if the phone is off but prompts me to change to pc suite mode which is not possible cause i cant open the phone to turn on. At the option of sending the phone to repair, i tried it but they are using jaf and c2-01 is unable to flash with jaf. Im afraid to send it to other shops cause they might chop my phone and replace parts without my knowing and say that they are unable to repair it.
  • 580 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Oct 25, 2012
4 Suggested Answers
  • 3 Answers
SOURCE: Hi, I have Nokia 3500 classic phone, now a days my
you have to load the software from the repair shop
Posted on Oct 21, 2010
  • 13 Answers
SOURCE: i can't connect my LG
The PC suite is found on your SD card. Connect the usb cable to your phone and when prompted enable SD card. Then select on your PC computer and you will see another drive being that of the SD card. Open the olders and you will see the install option for the suite. Install and follow the prompts.
Posted on Nov 22, 2010
  • 825 Answers
SOURCE: i use nokia 3110c mobile
Software complaint... Goto any authorized service center and ask them to re-flash the software..!
It will take only 15 minutes to flash the software... I have done this many times for my customers... It is also very cheap, In India re-flashing the software is done for just $5...
Posted on Feb 15, 2011
How can i formate my cellphone Nokia 2700 classic?
Just go to Settings > Restore Factory Settings then your phone will be formatted.
You may also want to update the software.
Download the Nokia Software Updater on your computer.
Plug the phone. Make sure it is set on General.
Connect using the PC Suite mode.
Run the Nokia Software Updater, select to download the firmware for your phone then just follow the instructions.
Mar 11, 2011 | Nokia Classic 2700 Cell Phone
Tip
How To Format(flash) Nokia Phones.
Formating is required only when your phone hanging,switching off automatically,forgotten the security(resets to 12345) code and when you want update your phones software.(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To back up your files
*Install the Nokia PC suit
*open Nokia PC suit >Select Back up
To restore Backed up data
*Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset
*A Computer
*Nokia PC suite of your handset
*Internet connection(Min speed 1Mbps)
*Nokia software updater(you can download by using Nokia PC suit)
To flash
*Install the PC suite
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option)
*Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Thank you
on Jan 29, 2011 | Cell Phones
My 3110c switches off iitself after 2-3 minutes everytime.I also changed the firmware but its not working.Plz anyone can help me.Plz give a solution for it!!!!!!!!!!!!!!!!!
Hi aaryandhunge....
If your phone is restarting you need to flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process.
Flash resets security code to 12345.
If your phone is switching of you need lock the battery correctly by putting a piece of paper.
or you need to change battery.
Thank you i hope tis helps feel free to ask queries.
Feb 16, 2011 | Nokia 3110 Cellular Phone
A general: memory full close some applications and try again appears everytime i send a message
Hi....
Try the following... *Restore your Phone once (To restore Goto Menu>Settings>Restore Factory Settings>OK(default security code is 12345)
*Clear some memory of Phone and Memory
*Scan your Phone and Memory
If problem persists you need flash your phone
To flash you need
I hope this helps... Thank you have a nice day
Feb 03, 2011 | Nokia E63 Cell Phone
Actualy i want to format my 3110c mobile phone memory but i can't.please give me solution
Normally Nokia and other symbian devices can be reset with *#7780# or *#7370#. if not you should find master reset in the general settings.
Feb 03, 2011 | Cell Phones
I cannot open messages from Inbox folder. Only able when I open it directly thru new message key shortcut shown on home page/screen once received. So I only get to read the message once and not able to...
Hi justinekaizz.......
You Problem is related to virus attack.
Try the following.
*Restore your phone once(To Restore Go to Menu>Settings>Restore Factory Settings>Ok(Default Security code is 12345)>Yes(It takes 1-2mins).
*Scan your phone and memory card from a updated anti virus.
At Last.... if Problem persists.....
You need to flash(format)your phone.
Formatting resets the security code to 12345
(formatting delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To flash you need
*A Computer
To flash
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(download the Nokia Software updater by selecting this option)
Jan 31, 2011 | Nokia E63 Cell Phone
How i can update my 5130xm software
Note: Before updating, you might like to backup your phone's contents using Nokia PC Suite. These can be restored once the update is complete.
update_with_pc_1.jpg 1) Download and install Nokia Software Updater (this need only be done once). update_with_pc_2.jpg 2) Connect your phone to your PC with a suitable USB cable and open Nokia Software Updater. update_with_pc_3.jpg 3) Follow the on-screen prompts until your update is complete!
Dec 13, 2010 | Nokia 5130 Cellular Phone
Nokia 6500 slide. Device Not Recognized
If you go to Control Panel -> System -> HardWare and check USB controllers which shud give you a list of all USB ports. Below that you will find Wireless Communication Devices. In this you shud find all the modes your phone is installed as. Check if all these settings are present. Secondly, install PC Suite now that you have restores the system to an earlier date. Connect the phone and connect.
Jul 28, 2009 | Nokia 6500 Slide Cellular Phone
N73 phone memory full
just update or reinstall ur firmware...throught pc suite new version...u just need original usb cable...
May 19, 2009 | Nokia N73 Cellular Phone
My phone cant finish restating/opening
REMOVE MMC BACK UP OF ALL UR DATA FROM PHONE MEMORY INSTALL NOKIA PC SUITE IN UR PC AND DOWNLOAD UPDATES FOR NOKIA MOBILE FROM NOKIA.COM INSTALL IT AND UPDATE UR MOBILE ONLINE.IT WILL FORMATE UR MOBILE AND RESET UR CODE TO 12345 AND ALSO fix ALL problem
do restore factor setting form setting menu it solve ur problems or backup ur data format ur phone use *#7370# code it remove all virus and corrupt file
i guarantee my solution is always right
plz dont forgetme to rate on fixya (blue line)
Nov 08, 2008 | Nokia 6270 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
