Question about Ricoh Aficio 450 Copier
Code 322 ricoh 2045 - Ricoh Aficio 450 Copier
  • 162 Answers
This code indicates that the laser is dirty, the signal of one of the diodes of the laser is not detected by the synchronism sensor.
Specialized personnel will need so that he carries out the work of cleaning.
Normally it happens when the equipment works with consumptions of low quality or when the cylinder is very low, this ocaciona that toner among others flies within the copier soiling the laser things, I recommend to use to toner of good quality if he is not original.
Posted on Oct 26, 2012
SOURCE: Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Posted on Jan 21, 2009
SOURCE: Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
Posted on May 11, 2009
joel_baleta
  • 155 Answers
SOURCE: add toner ricoh aficio 2045
Toner supply is controlled with readings from TD sensor on the developing unit and the I.D sensor above the drum by default.
These are low cost parts and easy to change.
(The TD sensor on this model have been known to fluctuate back and forth by a fair margin so is a good place to start).
You could also try stripping down and cleaning out the toner hopper.
Check the four mylars are present and the grabber is opening wide enough to grab the toner bottle nozzle successfully.
Check the toner hopper exit slider is opening fully when the PCU is inserted.
I had one of these 'add toner' faults today and it was the toner hopper all clogged up inside.
The side bit where the toner drops down had hardened clumps of toner stuck around the side entrance mylar and the exit hole.
Check also the toner motor. I have seen these fail. Run simulation output check for toner motor. I would remove the toner supply unit and hold the motor when you run this simulation. Sometimes the motor turns but does not have enough torgue to turn the toner supply unit.
Posted on Mar 06, 2010
santosj27
  • 263 Answers
SOURCE: sc 322 for RICOH AFICIO
That is a LASER error code.
It can be just toner dust because that error is a bad communication between the laser synchronization detector board and the LD unit.
Sometimes the dust of toner goes to the laser and causes this error.
Try to clean the laser unit. Maybe that work
Posted on Feb 24, 2011
SOURCE: error code sc 322 for
this is a laser unit problem.check laser connections clean the laser unit.
Posted on Aug 10, 2011
I have an sc 326 error code in my ricoh aficio 2045 copier
If you wish to get some details; check the site linked here. Pull up older posts....
Jun 19, 2016 | Ricoh Aficio 2045e 2035e Copier...
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
Error code sc 322 for aficio ricoh 2045
Aug 08, 2011 | Ricoh Aficio 1035 Copier
IN RICOH AF 2045 SC 990
This error code could be related to a Physical problem (machine) or Network Problem.
Physical problem:
Try to clean the ID sensor.
Probably you will also need to clean or replace the Drum Unit.
Network problem:
Upgrade your firmware.
(If you do not have technical skills a advise you to call your provider)
See you!
Jun 06, 2011 | Ricoh Aficio 2035 Copier
Sc 322 for RICOH AFICIO 2045
Feb 24, 2011 | Ricoh Aficio 450 Copier
I need to know the part number for the toner replacement bottle for the Ricoh Aficio 2045 PCL 6
Ricoh Aficio 2045 copier/printers take the Ricoh Type 3110D Toner Cartridge. Go with OEM toner on these machines. The generic version tends to make them run dirty.
Sep 09, 2010 | Office Equipment & Supplies
Ricoh Aficio AP 2600 laser printer there is a code SC-322
On most Ricoh models, SC-322 is a problem with the laser unit. If you have a service contract, have your technician take a look at the printer. Otherwise, you can either have a local Ricoh tech give you a repair estimate or buy a new printer.
On rare occasions you can turn the printer off and turn it back on and the code will be cleared, but most of the time this is a serious error that requires a service technician.
Apr 28, 2010 | Ricoh Aficio AP2600 Laser Printer
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
Mar 06, 2010 | Ricoh Aficio 450 Copier
Erro code SC541
Fuser error.
May 11, 2009 | Ricoh Aficio 450 Copier
Laser aficio 2045 (erro322)
ola ha a possibilidade de voce desmontar a LD INIT e limpar o LED do laser e os espelhos que ficam dentro do laser.
e um pouco trabalhoso mas da certo pois o toner derrama dentro do laser e ele nao consegue mais sincronizar.
precisa retirar 6 soldas das tres pernas dos 2 leds e retirar os parafusos.
May 10, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 450 Copier Logo
42 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
