Question about Dirt Devil Vacuums
No suction wont pick up anything from floor or attachments
    Scholar:
  • 44 Answers
I'm not sure what model you have, but the most common problems I've seen with these are that the hose gets clogged. Usually the hose is removable. If you can get it off, you may be able to push the clog out with slender rod or yardstick. If you are fortunate enough to have another vacuum with a hose, you can also **** or blow the clog out of the dirt devil hose with the other vacuum. Good Luck!!
Posted on Jan 03, 2009
Problems with suction on floor of vac
Often times when people bring a vac in for repairs and say it has no suction at the floor it has good suction but not good agitation. Make sure the belts in the clutch are new (some people are selling used clutches with stretched out belts) and the brush roll is good. If the agitation from the brush roll is not good it will not pick up even light soils like hair and lint.
Oct 08, 2017 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush does not turn. suction with the handheld unit it fine but when used as a floor sweeper it hardly picks up anything
these stick mmachines do not have a tremendous amout of suction at the best of times but if it has a full bag, or full dirt container, or dirty exhaust fiters it will take away from the air flow as well. take a flashlight and look up in to the tube of the floor attachment to see if you can see something blocking the tube.If there is no obstructions it may have a roller bar that spins on the bottom , so turn it over and turn it on and if it has a roller bar and it is not spinning it probably needs abelt . If there is no roller bar and no blo0ckage chances are it is just weak at the floor tool as the air a further to travel all the way up from the floor so it takes away from the air flow again. good luck.
Oct 07, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Dyson DC21 All Floors Stowaway
Simply answer Yes it would be but try and make sure the the old head is clean before dumpin it just in case
Jul 20, 2010 | Dyson DC21 All Floors Stowaway HEPA...
Blocked suction
Here is a tip that I wrote about my Bissel ... the hose should just pull out... it is just stuck in there tightly...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 28, 2010 | Royal 088500 Featherlite Upright Vacuum
Have a hoover model F5914-900 it wont spray anything out the hose attachment. The line isn't clogged any ideas?
Yes, one thing to try: With the hose attached, place your hand over the suction opening at the pick-up end of the hose. Then pull the trigger. The pump is suction driven, and if there is air in the water line in the hose, that is known to allow th hose to prime in about 10 to 15 seconds.
Mar 09, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Suction is so light when using attachments will not pick up anyth
If there is no obstructions, its probably the motor has burnt out or shorted, causing loss of suction. Good luck.
Aug 28, 2009 | Dyson DC14 All floors Bagless Upright...
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
It has been cleaned , yet there is no suction the hoover wont pick hardly anything up & it gets hot very quickly
Then there most be a clog either in the hose or the dirt inlet by the brush roll. If you pull the hose off like you are going to use an attachment, is there suction there. If not, then the problem is in the hose. If there is suction, then the problem is down below,
Jun 14, 2008 | Hoover Vacuums
Vacuums Logo
117 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
