Polygonal motor of the laser - Office Equipment & Supplies
leroyal
  • 2120 Answers
SOURCE: Brother MFC 9420FN Needs a
Try lubricating the mirror shaft, however, the ones i've fixed all had a bad circuit board.
Posted on Jan 16, 2009
  • 110 Answers
SOURCE: laser unit polygon motor failure
This error usually means that the laser unit on the machine has failed. Just replace the laser unit part number 116-1110-00
Posted on Oct 22, 2009
  • 123 Answers
SOURCE: sXerox 7700 Laser Polygon motor error 11
The error is caused by the laser polygon motor going bad. It is not difficult to replace but the calibration can be a little challenging. The part can be purchased at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
Posted on Apr 26, 2010
  • 123 Answers
SOURCE: unit 11 laser polygon motor failure
Most likely, all the problems you are experiencing are being caused by a bad laser motor assembly. We can send you a motor assembly for the laser unit and you can change it out yourself, however, we will have to charge for the entire unit since it makes one laser unit worthless. You would save on shipping that way. Aligning the lasers is a little tricky, but doable. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
The parts can be ordered at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
Joed911
  • 4338 Answers
SOURCE: On power up get the message "Laser Unit Polygon
That means that the Laser Unit is bad. I have fixed that error, by tahking the Laser Ubit's housing apart and removing the toner that accumalayes on the Laser itself. Proceed carefully, wipe tone off with cotton balls. If this does not fix it, it is the Laser Unit needing replacement.
Posted on Nov 23, 2010
Testimonial: "I thought it was probably the Laser Unit, but it was great to hear from someone that had the same problem. Thanks,"
"Service call0300 Polygon Mot"
Polygon motor is the motor located inside the print head where the LASER is at the motor is what moves the LASER beam across the drum when placing the image on the drum. SO you might have a bad print head because the motor and LASER come as one. And no you can not replace the motor separately.
Apr 03, 2015 | Konica Minolta Magicolor 5650EN Color...
How to solve error c4000 for Kyocera KM-2035 copier? it has stopped
c4000
The Problem:
inside the laser unit Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
May 29, 2014 | Kyocera KM-1505 Copier
ERROR CODE L6
Polygon motor lock detection
Detail : The polygon motor does not rotate.
The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock
signal is detected for 1sec during rotation of the
polygon motor.
Cause : Polygon motor unit abnormality
Improper connection or disconnection of the
polygon motor and the harness.
MCU PWB abnormality
Check and remedy : Use SIM 61-1 to check the polygon motor
operations.
Check connection of the polygon motor
harness/connector.
Replace the polygon motor..
Replace the MCU PWB.
Apr 30, 2014 | Sharp AR-M160 Laser Printer
POLYGONAL ERROR / WHAT DOES THIS MEANS AND HOW I WILL REST IT... THANKS
Polygon error. There is a LASER inside the machine which hits a 5 sided minor spinning at about 35000 rpm. That minor is spun my the polygon motor. More then likely you have a bad print head. That is what the entire assy. LASER/motor/Minor/Sensors are called. Power off/then on if it comes back have a technician looks at it.
Feb 26, 2013 | Minolta MF2800 Plain Paper Laser Fax
Where to purchase or fix a Minolta Di251 polygon motor?
Can't fix a polygon motor need to order the entire Print head which houses the LASER and polygon motor. try web site below if they have one Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 18, 2012 | Minolta DiALTA DI2510F All-In-One Laser...
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
Aparece el error SC 320 que puedo hacer??
320
Symptom
Polygon motor error
The polygon motor does not reach its operating speed within 10 seconds after the polygon motor on signal, or the lock signal is not detected for more than 200 ms continuously during operation.
Possible Cause
• Polygon mirror motor defective
• Poor connection between the polygon mirror motor driver and the SBCU board
• SBCU board defective
Nov 13, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
What does error code L6-10 mean on a Sharp AR-235 copier? Would it be worth fixing? Thanks
L6-10 Content Polygon motor lock detection
Detail
It is judged that the polygon motor lock signal
is not outputted.
Lock signal is checked in the interval of
10sec after starting the polygon motor, and it
is judged that the polygon motor does not
rotate normally.
Cause
The LSU connector or harness in the LSU is
disconnected or broken.
Polygon motor trouble
Check and
remedy
Use DIAG (SIM61-1) to check the polygon
motor operation.
Check connector and harness connection.
Replace LSU.
Jan 24, 2010 | Sharp AR-235 Copier
Error SC320 appear on screen..
Polygonal mirror motor error change...
The polygon mirror motor does not
reach operating speed within 10
seconds after the motor ON signal is
sent, or does not turn on within one of
the 200 ms check intervals during
operation.
• Poor connection between the polygonal mirror motor driver and the BiCU board
• Damaged cable between BiCU/IOB and polygonal mirror motor driver
• BiCU board defective
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Sharp ar-m208 message
Polygon mirror motor not up to speed. Check the motor, you power supply, and the board the motor it connected to.
Sep 23, 2008 | Sharp AR-M208 All-In-One Laser Printer
11 people viewed this question
jasbo
jasbo
