Question about Fujitsu Sony Vgn-z520n VGN-Z520 VGN-Z590 VGN-Z550N/B VGN-Z590 VGN-Z690 VGN-Z610 VGN-Z750D 13.1"" LED Screen LTD131EQ2X"
HDMI problems I can't get my laptop to display a picture on tv through an HDMI cable
  • 3 more comments
  • Al G C Oct 25, 2012
    Is there HDMI settings to adjust and where do I locate them? I have had it working through this tv before
    the model is sony vaio VGN-FW23G with vista
    can you please help with process to find HDMI driver software in windows
    how do I get to HDMI driver settings
  • Al G C Oct 29, 2012
    PROBLEM SOLVED THANK YOU
Make sure you're using theright 'type' of HDMI (if I remember correctly you have 'fast hdmi with build in lan and standard video/audio only hdmi). make sure your pc is fast enough, since hdmi is software based and therefore not 'just a copy' of your screen but rather a second screen. In fact, I would reccomend using a standard VGA or DVI to display on a tv, since it is faster an less hardware intenstif (higher resolution/ less stress on onboard video)
(if you have an older pc, this is the way to go) and use external speakers for your sound
Posted on Oct 25, 2012
  • 14 more comments
    I have had it working on the tv through HDMI cable before. How do I adjust settings or the process to do this?
    I have already turned computer off with the tv and plugged cable in like windows help suppport said to do. When the HDMI cord is plugged in it loads something but won't bring picture up on tv?
  • Lieven P. Oct 25, 2012
    do you mean the VGA/DVI method or a fix for HDMI?
    If you want to stick to hdmi, make sure your hdmi display driver software is working. In windows, you should find a driver saying 'HDMI display driver' or someething in the hardware configuration panel. make sure its workign fine or try reinstalling it
    Did you change the input channel of your tv to hdmi (sometimess there are mor than 1 port so select the right one
    yes have selected the right channel on tv as have another laptop working on same channel. what do I go into to get to hdmi driver software? the process?
    want to fix HDMI not vga/dvi
    on windows, you'll find your hardware configuration in config panel -> hardware and sound ->device managment (may be translated,
    also try thihttp://www.ehow.com/how_7159566_connect-...
    can you guide me through thr process
    ok when your connected, right click your desktop and select 'screen resollution'. there you can select the screen. select 'multiple screens' in the drop down menu and then, in one of the other drop-down menus, select HDMI-output/HDMI screen or something similar
    to better your performance, select 'display only on " and then the preffered screen (external tv or lokal onpc)
  • Al G C Oct 26, 2012
    I cant find an option for multilpe screens?Add a Comment
    by right clicking on desktop I only get the personalise menu. I want to be able to get my HDMI settings up so I can connect to a tv on a HDMI cord
  • Lieven P. Oct 26, 2012
    just right click and select screen resolution. or , go to config panel -> search for display an go to resolutions
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Posted on Feb 17, 2009
  • 220 Answers
SOURCE: Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Posted on Jun 26, 2009
SOURCE: cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
Posted on Jan 19, 2009
  • 55 Answers
SOURCE: can't view laptop display on panasonic plasma using hdmi cable
If you are using windows, try going to the screen resolution page(right click desktop and click properties and then click the last tab for xp, or right click desktop and click personalize and then screen resolution. There you should see two black rectangles. Click the second one(he one that's grayed out) and set a resolution in the dropdown menu. Then the tv should show your computer screen. You can also fool around with the resolutions. Good luck!
Posted on Sep 13, 2009
piyushclal
  • 148 Answers
SOURCE: no picture dv5 HDMI
Connecting  an HDMI cable is not the only solution to share ur laptop screen over ur tv set
u've to change few settings from the laptop so that u can see or operate it from TV.
SImply go to ur Control Panel, Open Dipslay Properties, Go to Properties & select Displays. Then Identify & change ur default display from ur laptop display to ur HDMI Display. Its done
If this works, please rate me up, i really need some good ratings.,...
If this does not work, feel free to ask again
thanks !!!
Posted on Dec 13, 2009
Testimonial: "Awesome!!! thanks!"
ACER 4750G failed to display properly on Pana 50"
Are there Picture settings in the TV menu?
Apr 26, 2013 | Acer Computers & Internet
Laptop will not connect to tv
the tv might not be able or new enough to handle the picture of a laptop or computer check to see if it is able to
Apr 23, 2013 | JVC Televison & Video
Acer 5920g, nvidia 8600m gs. the problem is that when I connect hdmi cable from tv to laptop, laptop screen freezes, and tv screen display hdmi logo, but without picture, If I disconnect cable, tv starts...
check windows optional updates....or try booting up with tv already linked....ooo check the display settings for dpi and Hz some tvs wont go above 60Hz
Nov 19, 2012 | Computers & Internet
Can someone please help me get my laptop working through HDMI cable onto TV on a sony VAIO VGN-FW23G. I need to know the process to do this
1. Check the computer for changing output (some computers use <F5>, <F8>, depending on which brand they are. I believe Sony uses <Function><F7> or <F7>).
2. Check what channel the HDMI port is on (e.g. AV1, HDMI1, HDMI2, etc.) - you need to know this if your TV doesn't automatically switch to the new input.
3. Plug the HDMI cable into the TV HDMI cable-in port.
4. Plug the HDMI cable into the laptop HDMI cable-out port.
5. Turn on the computer.
6. Press the <Function><F7> simultaneously ONCE. The screen should flicker and show up on TV.
7. Sometimes you may have to go to "Display Preferences" and select Dual Monitors or external monitor if your computer doesn't do it automatically. Repeat Step 6 after.
** You may have to adjust Display Resolution to 1024 x 768 or lower in order for the TV to work. After it works at a lower display (800 x 600, for example), you can adjust the resolution to the maximum the TV can accept.
Oct 26, 2012 | Fujitsu Computers & Internet
What's your problem?can not hook up lap top to tv
Connecting your laptop to your TV will require a HDMI cable. Attach the cable to the HDMI ports on the latop and TV, then change the source input from your TV to HDMI and your TV will now display your laptop.
Jan 30, 2012 | Televison & Video
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
How do I conect my Acer aspire 5750 lap top to my sony hdmi tv. I have recently brought a VGA cable that allows me to connect my laptop to my tv. The problem is that everytime i connect the tv and the...
"Out of range" means that the picture displayed by the laptop cannot be displayed by the TV, either because the resolution is not supported or the refresh rate is not supported.
Sometimes, I've had to set the refresh rate (from the laptop Display settings) to 59Hz to get it to work as opposed to the default 60Hz.
What resolution does your TV support? What resolution does the laptop support?
Matching these as closely as possible and you'll get the picture on the TV screen.
Good Luck and let us know how it goes,
-BuzzPuppy
Apr 30, 2011 | Acer Computers & Internet
No picture dv5 HDMI
thanks !!!
Dec 13, 2009 | HP Pavilion dv5020us Notebook
Hdmi to panasonic tv no desktop display only
I can help with getting your desktop onto your TV, but sound from your computer through HDMI can be much trickier.
If you only see a background picture on your TV, then your desktop has been either "extended" or "stretched" onto it. It is essentially a second independent monitor and you can drag applications over to it to see them.
To view your desktop and start menu on your TV, you need to run ati catalyst and "clone" your TV with your computers monitor. Do this by right clicking the picture of the second monitor in the catalyst display manager and choosing "clone". Now your tv and your monitor act as one.
Although i tried 3 different ati cards with hdmi outs that claimed to pump audio through hdmi, none of them worked for my HP PC. You will need a grey widget adaptor between your computer and the hdmi cable. In the end though, there's a conflict between my sound card and ATI's HDMI audio that cannot be resolved. So I run a digital SPDIF signal instead through an rca cable and get 5.1 dolby at my amp that way. Good luck.
Sep 20, 2009 | Acer Aspire 3000 Notebook
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
Fujitsu Sony Vgn-z520n VGN-Z520 VGN-Z590 VGN-Z550N/B VGN-Z590 VGN-Z690 VGN-Z610 VGN-Z750D 13.1"" LED Screen LTD131EQ2X" Logo
258 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
