Question about Tally T2240/24 Matrix Printer
The printer feeds to much papper
I have fanfold papers 1,25 x 3 inches installed **** the printer feeds A4 size when it has printed it. How do I change the setting so it only feeds out this form when it has printed it ?
    Novelist:
  • 169 Answers
The first thing you need to do is to check the paper size selected in the application you are printing. If you are printing from a Windows based application you WILL find that the paper size selected in the application you are printing from is set to A4.
On the printer you can set the paper size in the following way;
  1. Power the printer ON holding down the SETUP button to unlock the menu, release SETUP when the printer finishes initializing
  2. Put the printer OFFLINE press SETUP
  3. Press the button under MENU
  4. Press the button under NEXT until you see FORMLEN (if you do not see FORMLEN select the PAPER option it may be a sub menu for PAPER)
  5. Press the button under TRACTOR 1
  6. Press the button under LINES
  7. Use button 2 to reduce the number of lined to 18 (3 inch x 6 lines per inch)
  8. Press the button under SET to save the setting
I am assuming the form length is 3 inches, if it is 1.25 inches this may be outside the specification for the printer and you may not be able to select this it is also not dividable by 6 lines per inch
Posted on Nov 18, 2012
3 Suggested Answers
SOURCE: thiruvallmy tally t6050 shows paper
phase problem facing t6050.
Posted on Jul 06, 2011
  • 169 Answers
SOURCE: After creating a new form of size 15 x 12 fanfold
THe T6215 can only print a maximum width of 13.6 inches. If you create a form wider than this Windows will not allow you to select this form within the printer driver as the printer is not physically able to print this wide. Your paper may be 15 inches wide but it is unlikely you will be printing 15 inches, simply create a form whose width is equal to the maximum print width or 13.6 inches. You will then be able to select this form in the printer driver.
Posted on Dec 12, 2011
Code PC Load A4
This means that the printer is expecting A4 paper rather than letter size or whatever you are trying to use. Check your "Printer Options" on your computer and make sure that the appropriate paper size is selected. A4 is an international standard paper size that is 210 mm (8.27 inches) x 297 mm (11.7 inches) and therefore is just a bit narrower and longer than the American "letter" paper size.
To correct this, cancel the print job currently in the printer's memory, change the computer to the proper paper size, and send the print job again.
Jan 26, 2014 | HP LaserJet 4 plus Printer
Hello! I have a Magicolor 2300W that has been standing unused for some time and it won't print correctly. The printer feeds paper from the tray, it goes through the printer, comes out at the top - but...
1. Check the paper size your printing on and whether the Same is used by printer or not 2. Try shaking the cartridges as they may have got stuck at their places for long time 3. Try legal or a4 or letter size for paper
Jan 01, 2014 | Minolta magicolor 2300W Laser Printer
After creating a new form of size 15 x 12 fanfold in the printer settings option, form is saved but not applied. So after selecting printer in a software, the paper size option of 15 x 12 fanfold does not...
Dec 13, 2010 | Tally T6215 Matrix Printer
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    For printing us std fanfold size in msp 345
    right click on the printer driver and select the properties ....> printing preferences ....> advance .....> change the page size to fan fold size ...> ok..>ok ...>ok
    if you want to set your own paper size then open the printer and faxes ..>file ...>server properties ...> in forms tab ..>select create new form
    Nov 18, 2009 | Computers & Internet
    Hp laserjet p3005dn tray1 manual feed problem
    you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
    Jul 25, 2009 | HP LaserJet P3005n Printer
    Do i can customize my paper size in MS Excel 2003
    When you are in Excel, go to Print Preview, then Printer Properties. There should be a box that says "Custom Size." There you can input your paper size and name it so you can recall it anytime you want.
    Dec 18, 2008 | Epson FX 1170 Matrix Printer
    Paper size
    The problem is with the printer side. there is option in the printer, Set manualy paper size from the printer paper tray. I think this will help you.Goodluck.
    Mar 10, 2008 | HP LaserJet 5550DN/EN Printer
    Small photo paper
    have you set up the paper size in the printer options when you press print, as it should pop up in a window before the print whre you click ok, asking what quality and size paper, but if you don't tell it it will assume that you are using standard A4 or whatever your standard paper size is.
    May 27, 2007 | HP Photosmart 7450 InkJet Printer
    Tally T2240/24 Matrix Printer Logo
    126 people viewed this question
    Top Tally Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
