Question about Dewalt 18v Battery Hammer Drill Dcd950 Dc925
Removing chuck from dewalt dcd925 - Dewalt 18v Battery Hammer Drill Dcd950 Dc925
    Top Expert:
  • Dewalt Master
  • 51,188 Answers
Open chuck and look in the bottom of it (chuck)there is probably a screw there. think it will be left hand thread
Posted on Jul 02, 2015
  • 178 Answers
SOURCE: remove c keyless chuck from 18v dewalt drill
There is no loctite on the chuck threads, only blue loctite on the reverse screw. This is how I remove chucks.
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck). Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Posted on Nov 26, 2010
Gigatech
  • 259 Answers
SOURCE: dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Posted on Mar 05, 2008
smjdragonfly
  • 79 Answers
SOURCE: Having problem to remove chuck to replace it on dewalt dc988 18v
Inside the chuck is a left-handed screw. torx (star) T20. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Please rate me
Posted on Jun 18, 2009
Testimonial: "Thank you very much. solved my problem last year or so...George"
rtpflh
  • 546 Answers
SOURCE: Remove chuck and replace
the chuck is retained by a screw in the center of the chuck.open chuck jaws wide.use a vise or pipe wrench to hold chuck.
Posted on Oct 15, 2009
SOURCE: removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Posted on Oct 18, 2009
How do i close the chuck on a dewalt dcd950
The DCD950 was DeWalt's worst chuck design. This chuck has no chuck screw, they loaded the spindle with locktite and put them on. Consequently, the chucks are nearly impossible to remove. DeWalt made a tool for this purpose, but it costs almost $90 - the only alternative was to replace the gearcase assy but they just made it obsolete, no longer available.
There is a conversion kit but the problem remains, you still need to be able to remove the old chuck.
We have used a metal cutting saw to cut the chuck off - about the only thing that works Conversion Kit N422782 for DeWALT Power Tool eReplacement Parts
Sep 25, 2014 | Dewalt Dcd950 Hammer Drill Uses Dc9096 Or...
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
Problem with the Dewalt 3/8"VSR
My solution when the other mentioned ideas didn't work was this: I removed the 7 Torx #20 screws ( a common screw driver will work as well) and removed the housing half to expose the shaft. The chuck shaft bearings and gear lifts out as one assembly. Directly behind the chuck there is a half inch section of shaft exposed. I mounted a vise grip on the shaft (won't hurt it) and clamped the affair in a bench vise. With a 5/16" allen wrench mounted in the chuck and using a mallet I spun the chuck off with a solid smack counter clockwise . Very simple and easy .
Aug 29, 2011 | Dewalt 3/8"VSR 6AMP CORDED KY DEWALT DRILL...
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Best regards, --W/D--
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How to remove the chuck?
open the chuck fully and it shoudl have a screw inside. Unscrew it, but be carefull, these screws are usually reversed - to uncsrew, rotate it clockwise. Once done, put allen key into chuck (short side in), fasten the chuck to hold allen key well and hit the key with hammer - counterclockwise direction. You might want to verify this procedure with someone else as I have no experience with Dewalt, but this way it works for Makita, Metabo, Narex, ... then why not for Dewalt? Juraj
Jun 06, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Remove chuck and replace on DeWalt DW959
Oct 15, 2009 | Dewalt Drills
How do you remove a key chuck from a dewalt drill
first shift the drill to the drill only position and the gear selector to the low position, remove the chuck retaining screw LH thread, find a bent handle allen wrench about the chuck capacity and lock in the jaws of the chuck, put the chuck on a block of wood at about a 30 degree angle to hit the long portion counter clockwise and strike it with a hammer, it might take a couple hits but it will come off. I misread the header last time.
Oct 01, 2009 | Dewalt Drills
Dewalt 18v Battery Hammer Drill Dcd950 Dc925 Logo
574 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
