Question about Serfas FMP500 Floor Pump
Serfas FP-200 needs new Guage Cover - Serfas FMP500 Floor Pump
I have misplaced the Manual for serfas level 2.2 and was hoping to find a replacement here.
Fixya is a place to ask people questions, not to obtain things directly. Usually the best thing to do first is search Google, but I could not find a manual for your computer that way, so I'd suggest you contact Serfas: https://www.serfas.com/contact-us
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Sep 05, 2017 | Serfas Cycling
Is there an instruction manual for the Serfas USL-3 front light
Ask SERFAS...
http://www.serfas.com/about.asp
Serfas, Inc
29752 Avenida De Las Banderas
Rancho Santa Margarita, Ca 92688
T 800.424.0047
F 800.825.9641
info@serfas.com
Sep 19, 2011 | Cycling
How do I change from kilometers to miles, in both distance and speed?
Any search engine would greet "Serfas WC-4 manual" with the link to it.
http://www.serfas.com/product_details.asp?ID=594
It is always a good idea to try a few web searches before resorting to Experts. That's where we frequently start. Eliminate the middleman.
Aug 09, 2011 | Serfas WC-4 Level 4.4
I have a Serfas airbones and it is not functioning or perhaps I am not using it correctly. How do I use it on a road bike?
I am assuming you are trying to inflate a presta valve.
If that still doesn't work, your pump may need new seals, or is damaged in some way.
Jul 27, 2011 | Serfas Cycling
What do the number guage on the seat bracket mean to adjust the seat over the pole? I don't have installation instructions? what is the best number setting
The etched guage is for your reference once you've set it and so you can reporoduce it if you remove the seat for any reason. You adjust, you try it out, you readjust if necessary. YOUR preferred riding position will not be found on a chart or in a manual.
May 07, 2011 | Serfas Rx Men's Saddle
I have a Serfas WFP-200 Floor Pump. I don't have a manual or instructions for it. I just recently brought out my bike: women's Giant bike, which I haven't used for four years and the tires were flat. I...
you may have a presta valve which is a different compare it to the one on your car lets say if they are the same you imple place the pump nozzle on the tube and open the lever to lock in place is indeed it is presta the have a much smaller size simple open the nozzle and flip the to pieces inside to allow the pump to be presta capable ok also you will need to screw open the presta valve before trying to pump ok if its still alittle frusterating simply bring in the pump to your local bike shop and they will be more than happy to give you the low down on the pump functions ok :) happy riding ok :)
Feb 23, 2011 | Serfas Cycling
When using my new Serfas floor pump air doesn't go into the tire. The line pressurizes but nothing in the tire itself.
Do you have the connection to the tire valve tight? You must have the connector pushed completely down and the locking lever pushed in the down position. Be sure it can not be pulled off of the valve while pumping up the tire.
Feb 12, 2011 | Serfas FP50 Floor Pump
I need plain paper fax panasonic kx-fp 200 immediately
The refills that fix the kx-fp135 will also fit your model kx fp 200. Office Depot has this and it can be ordered onlin. : http://www.officedepot.com/a/products/288514/Panasonic-KX-FA136-Black-Imaging-Film/
Apr 16, 2009 | Panasonic KX-FB421 Plain Paper Film Fax
Serfas FMP500 Floor Pump Logo
Top Serfas Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Serfas Cycling Expert? Answer questions, earn points and help others
