My copier ar-m155 machine is showing replace toner catridge
Each time you put it on it shows replace toner catridges
  • 990 Answers
SOURCE: Replace tonner catridge error
Dear Sir; You fill up the cartridge that's fine,but you forget to change RF chip, it located right behind the cartridge, if you don't replace it , machine not going reset .
Posted on Jan 10, 2009
  • 74 Answers
SOURCE: copier
The problem is that the toner sensor is not recognizing that type of toner. All toner is not the same you will cause more damage to the machine. Use the specified manufacturer toner.
Posted on Apr 01, 2010
  • 360 Answers
SOURCE: i have sharp AR 5316 when i power on toner blink
check your developer unit wheel set .i think it was broken.that 's why didn't add toner
Posted on Sep 09, 2010
SOURCE: HOW DO I REFILLED MY
Don't try that you must replace the hole cartridge
Posted on Dec 25, 2010
hamzaskilltd
  • 316 Answers
SOURCE: I am using Sharp Copier Model no: AR-5320 and when
F2-04- Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
Posted on Dec 30, 2010
Xerox 7335 Yellow Drum catridge did not shows.. Catridge is perfect but did'nt shows...
Make sure deal has been removed pull out press cancel 30 seconds...power off on the put back in
Jun 28, 2016 | Miscellaneous
How to fix replace toner cartridge problem when there is enough toner in the cartridge.
Remove from the printer, give it a good shake over the sink, (you may find toner leaking and it is hard to cleanup...then replace it. That may do the trick but if it does not you may be best off replacing the cartridge. Sometimes old electronics misreport the condition of components ....it could be that the machine is getting old and going wrong. But you will only discover whether this is the case after investigating further)
Oct 26, 2015 | Sharp Cartridge Copier Toner/Developer...
AR-M155 keep complaining of change the ink cartridge.while the cartridge is working perfectly with another printer. pls what step should i take please what is the next step to take
well some times you do get bad cartridge is this third party if so replace the cartridge with a OEM. Is there a chip on the cartridge if so clean with alchol also clean the contact inside the machine where the chip connects, buy a new one OEM do not use one from other machines there chips already have data about that machine not the new one
Catridge of Sharp mf420u
When the toner supply not attached the properly than comes this problem.
Better way you open the toner and check all toner supply gear ,if gear is jam than you should replace the toner.I think your toner chip version problem or destination problem.
May 29, 2014 | Sharp AR-5316 Advanced Digital Imager...
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
My copier machine sharp AR5316E shows error message 2U, please what is the solution?
remove the catridge to the machine and then insert it back. if it still display the same information the catridge might be damaged need to be replaced.
Feb 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
I would like to change the toner how to change it machine is toshiba e studio 45
You have to purchase genuine toner catridge from toshiba dealer . after purchasing the toner
1) Open the front toor
2) Toner catridge is there on above of the drum unit, there will be lock for toner catridge cover on the machine, it needs to be opened
3)Rotate the toner catridge in clock wise and pull the catridge ,it will come out
4)Insert the new catridge and rotate clockwise at a time it will get enhance with toner motor
5) close the toner cat cover, front door, TURN ON the machine it will get rotate for few seconds (adding toner) then it will becomes ready
May 20, 2010 | Toshiba e-Studio 45 Black and White Copier
Samsung scx-4200 refilling second time
CAN I RESET MY SAMSUNG SCX4200 TONER CHIP MANUALLY BY SOLDERING
Jul 05, 2009 | Samsung SCX 4200 All-In-One Laser Printer
k24674
jasbo
jasbo
