Question about Intel D865GBF Motherboard
Intel d865gbf does not recognized back USB port
  • Intel Master
  • 3,606 Answers
Hello you probably just need a driver for the mainboard
Its here for download:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+865+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D865GBF
Start with the chipset driver and download the other ones if needed.
Good luck
Posted on Oct 25, 2012
3 Suggested Answers
SOURCE: Melfunctioning of USB port
thanks for the solution, I'll try it then I tell you
sushant tudu
Posted on Jul 24, 2008
map9966
  • 2351 Answers
SOURCE: suport hdd sata intel d865gbf?
The Intel D865GBF motherboard.
Supports 2 Serial ATA (SATA) connectors, see page 39 in your manual.
The serial ATA SATA ports will support Version 1.5GBs SATA drives not 300GBs
If you no longer have your manual, download it from Intel. Click on the link below;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22d865gbf%22
Mike
Posted on Oct 16, 2009
Acer Aspire 5102WLMI \ After booting stps for Password. System does not accept any input . Input rom touchpad, key board, Usb keyboad. No usb port is working. I guess, the power may not be coming to these...
On the Motherboard, set the BIOS Configuration Jumper for pins 2 & 3 to clear the password. Turn on the PC for a few seconds and then power it back down and restore the BIOS Configuration Jumper back to normal. The password is now cleared.
Jul 02, 2011 | Intel D865GBF Motherboard
Suport hdd sata intel d865gbf?
Mike
Oct 15, 2009 | Intel D865GBF Motherboard
Intel D865GBF motherboard's onboard sound card is not giving signals to speakers . Sometimes only left speaker works but mostly none of them works. I tried many media players & many speakers. But while...
it is the problem with the back side motherboard sound port.
so u can purchase another sound card and install it. it cost about 6$ (Rs 300.00 )
If it helps RATE ME PLS
Jun 25, 2009 | Intel D865GBF Motherboard
OnBoard USB ports (both front and back) will not recognize any devices
When you reloaded the OS did you reload all the drivers? Sometimes if you do not reinstall the Intel driver the USB port will not be recognized. Happened on the last two DELL's I reloaded. Go to DELL's website and download all the drivers for your model.
Dell support website http://support.dell.com/support/downloads/
Look up your model by service tag, it is the alphanumeric code on the barcode label on the back of your DELL and also sometimes found on either the front or top of your DELL (sometimes it is hidden beneath the USB port cover that you flip up.
Try that and see if it fixes it. Also make sure that the connector did not come loose when you opened the case.
Apr 30, 2009 | Dell Precision 360 Workstation/Personal...
Intel desktop board d865gbf model & i am facing sound problem.
Sorry bud it will not accept any new drivers afet installing Vista. WinXP would have allowed you this freedom, now the best option is t change your sound card which is certified as Vista compatible and insert it onto any PCI slot & Vista will recognize it......sodeep
Apr 05, 2009 | Intel D865GBF Motherboard
Nvida geforce fx5500 256 agp compatible with intel d865gbf ?
Yes, they should be compatible. The Intel d865gbf has an AGP port that supports AGP 4x/8x, and so does the FX5500. You should be fine.
Nov 05, 2008 | Nvidia GeForce FX 5500 Video Card Graphic...
Compatible board for P-4
ok so its a 478 socket
best board available is an asrock P4I65g
Specification Value Product Description ASRock P4I65G - motherboard - micro ATX - i865G Product Type Motherboard Form Factor Micro ATX Dimensions (WxDxH) 24.4 cm x 19.8 cm Chipset Type Intel 865G / Intel ICH5 Max Bus Speed 800 MHz Processor 0 ( 1 ) - Socket 478 Compatible Processors Pentium 4, Celeron D RAM 0 MB (installed) / 2 GB (max) Supported RAM Technology DDR SDRAM Storage Controller ATA-100, Serial ATA-150 USB Ports Configuration 4 x USB Storage Ports Configuration 2 x ATA, 2 x SATA Graphics Controller Intel Extreme Graphics 2 Dynamic Video Memory Technology 2.0 Audio Output Sound card - 5.1 channel surround Networking Network adapter - Realtek RTL8101L - Ethernet, Fast EthernetView extended Specifications
Oct 18, 2008 | Intel D865GBF Motherboard
Driver
For any computer there will be at least 4 usb ports. 2 at the front and other 2 at the back side of cpu. If any one is not recognizing then insert it in different usb port. If any of the port is not working then install the driver for your usb port. Download the usb driver from the below link.
http://global.msi.com.tw/index.php?func=downloadindex
Thank you......
Sep 13, 2008 | Intel Motherboard
Related with Sound
For Intel Desktop Board D865GBF, pls try here. Select your Operating System, and click on Audio: ADI* 1985 Driver.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 16, 2008 | Intel D865GBF Motherboard
Media Card Readers
yess use the ports in the back of the computer I had the same problem with my mouse before which was also usb port connection. The reason why I say to hook it up to the back usb ports is that it is built onto the motherboard and therefore it would get recognized alot quicker if you put it there if you find that whatever you have hooked up dont have alot of usb ports buy yourself a usb hub i bought one for 2.00 it does the trick when you are limited to usb connections
Sep 26, 2007 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
Intel D865GBF Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
