Question about Panasonic Electronics - Others
I have a Panasonic inverter airconditioner Model CU-RE9JKR with a constant flashing timer light unit will not turn on?
Model CU-RE9JKR
  • Leah Kane Oct 25, 2012
    I have reset via the remote, power board and external power switch. this resets the unit but does not solve the problem?
    If anyone has a link to the manual for this product it could be helpful?
5 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Posted on Jan 07, 2008
SOURCE: Fujitsu Inverter ASTA09LCC - heating not working
Use a pen to hit the reset button on the remote.
Posted on Feb 11, 2009
farfield
  • 462 Answers
SOURCE: Good morning,
First the thing that's causing the thermostat to act up Could be the thermostat being bad.
The blinking does it continue for hours on end and nothing runs? If so the thermostat LOCKED OUT. Now what caused this???
I proceed with the assumption that the controls are 24vac.
Depends on how the thermostat is communicated with and how it interprets the information its getting. Could be a real in depth problem, like low refrigerant or low air flow. Both of these problems could be caused by a fan not running when it should, or shutting off when it should not or a dirty filter.
If it doesn't have a "code" telling you any information then its locked off most likely.
First lets see if we can narrow or trouble down by looking outside and inside units til the problem happens. Assuming you noted nothing to show you any place to concentrate on outside or inside (like both fans run, air filters clean, all duct dampers open... ) concentrate on eliminating the thermostat.
Most important if your system has a special thermostat, room sensor, or more than 5 wires to thermostat are used: You have something that you need a tech on because it is impossible to cover all the bases here.
To eliminate the thermostat as the source of the trouble;
1 Kill power to indoor section as this is where the thermostat gets pow from most often.
2 Make a diagram of the wire terminals and label them and put the colors down as to what colors go where. (Colors mean nothing except to the person doing the installation, troubleshooting, or wiring, so he/she wont get lost and keep things straight. On controls, color could be any color but these terminals on the thermostat can not be they have a reason to be marked.)
Now you can disconnect the r,g, w, and y wires (all of them) Usually only 4 on a simple hvac system.
Now put the wires that were on R Y and G together. Stay close to the indoor and out door units for the time limit that the problem used to have if it doesn't reoccur within the previous lime limit plus time and nothing is noted as to sound or speed or other, Id have to assume its the thermostat because you just did what the thermostat did only manually.
If this helped you trouble shoot or decide your next step please rate ma as high as you can.If you need more please post back with what you found on your tests and what changed or what you noted different.
Thank you for using Fix Ya and good luck.
Posted on Mar 27, 2009
SOURCE: panasonic inverter model locked. How do I unlock
i have probleam with panasonic inverter model NN-SN977S ON SCREEN H97 NOT MOVING
Posted on Feb 10, 2010
Panasonic CS-E24FKR Airconditioner keeps turning off. Error code 15 H
Is the air-conditioner plugged into an extention cord or directly into the wall outlet???
Aug 20, 2016 | Panasonic Heating & Cooling
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
MY FIJITSU inverter is not working correctly, the timer light is flashing continuously and the timer lights flashes 5 times can anyone help pleawe
fujitsu is a good brand.
try one of these two things:
Turn the unit off then on again. After that press test button on remote control (rear side) and look how many times now operation and timer LED flashes. Note that. Then press MANUAL/AUTO button on indoor unit until you hear 3 beeps from buzzer. That will erase error memory.
Switch off and than on unit and see if indication repeat or it is gone. If it is gone, keep using your unit.
If it is repeated post your notes here.
OR+++++++++++++++++++++FOR OTHER MODELS
5 x Operation flash and a constant Timer flash indicates an outdoor unit control error. With this code flashing on the indoor unit, you need to point the remote at the unit and push the test run button. The flash pattern will change to a continuously flashing Operation light and a number of flashes of the timer light which gives more detail on what the error is.
To get the unit to try to restart you need to push and hold the manual/auto button on the indoor unit for a few seconds then reset the mains power supply but leave it off for a minute or so for the unit to power down completely. If you are going to try this make sure you make a note of any error codes first if you have to get someone out to look at it, it will help them a lot.
Jan 05, 2015 | Inverter Heating & Cooling
Indicator light keep blinking for SHARP ECO INVERTER
The unit has popped up an error code. There is something wrong with the unit. What is the model number? 25325502-u40lsvyytnuesyuv3fbafhtd-1-0.jpg
Dec 16, 2014 | Kenmore Ac Airconditioner Remote Control...
Panasonic power light flashing air not cold blowing
hi there you need to see where you bhave a gas leak thats all the flashing light indicates that your gas pressure is to low to activate your compressor
Dec 09, 2013 | Panasonic Heating & Cooling
Panasonic heat pump timer light flashes
check if it is poor contact .or current is too small.
wall light
May 20, 2012 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
I have a Panasonic air conditioner model CU-E12EKU (inverter). The unit stop working and the timer indicator is blinking. I checked for this error and followed the instructions in the Operating Manual,...
Not sure if yours has a letter 'H' before the 16 but if it does, it's the:
- Outdoor Current Transformer open circuit.
which means that your outdoor controller board is faulty.
Sep 08, 2011 | Panasonic Heating & Cooling
Split system airconditioner Panasonic model CU-A28CKR.not responding to remote
Try turning of the power to the unit.Wait 60 seconds and try it again.This may reset the unit.
Nov 24, 2007 | Heating & Cooling
Electronics - Others Logo
Top Panasonic Electronics - Others Experts
 Grubhead
Grubhead
Are you a Panasonic Electronics - Other Expert? Answer questions, earn points and help others
