Question about Asko T731 Electric Dryer
Asko dryer heating element location
Where is the heating element
4 Suggested Answers
kingbrizzle
  • 407 Answers
SOURCE: Asko dryer: room temp air, is not heating
I would first make sure the dryer vent is cleaned out really good, from inside the dryer all the way out of the house, and make sure it isn't blocked anywhere. Thats usually what causes this type of problem. If not, then yes, it will be an electrical problem. Hope this helps.
Posted on Dec 28, 2009
Macmarkus
  • 2605 Answers
SOURCE: Asko T701 dryer not heating up during drying
Welcome to FixYa.
I hope to clarify the thermostat's you refer to. Attached below is the location of the cycling thermostat`s ( I suspect these are the ones you checked ? correct me if I'm wrong ) but there is one many people miss and are unaware of also shown below, that is the hi-limit safety.
The location of the reset-able safety thermostat in the second image, It is on the back wall under the black rubber cap I`m pointing at in the 2nd photo.
Cycling in front blower
Hi-limit reset-able thermostat.
There is a possibility the heating element is at fault of course, but I'd like to clarify you've ruled out the hi-limit before proceeding to the heater check/repair.
Thanks for choosing FixYa. Please take a moment to leave a testimony and rate the info I provided.
Good luck.
Regards,
Macmarkus :)
Posted on Mar 03, 2011
KevinWhite
  • 1902 Answers
SOURCE: My asko dryer 7005 works
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermostat. When the thermostat goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, if thermostat reads continuity then please get back to me if you have any other questions.
Kevin
Posted on May 22, 2011
Testimonial: "Thank you for your response. Should we replace the thermostat as well as the heating element"
We just replaced the heat element still no heat any ideas
Contact asko... did you check the power going to the heating element. Or the control panel. If the unit doesn't know to work it won't I would check everything form the heating unit back
Sep 03, 2014 | Asko TL751 Electric Dryer
My asko dryer 7005 works but there is no heat. Do you think the heating element needs to be replaced? Thank you
Kevin
May 22, 2011 | Asko T700 Electric Commercial Dryer
Asko T701 dryer not heating up during drying cycle. Have already checked thermostats which are ok. Where do I find the heating element? Is a diagram available?
Welcome to FixYa.
Good luck.
Regards,
Macmarkus :)
Mar 03, 2011 | Asko T701 Electric Dryer
Asko 24 el dryer does not run,no indicator light,Mod 10776110,LMBent
Check the house electrical panel for tripped dryer breaker pair. Push off, then on to reset. If breakers trip again, you have a short circuit within the dryer case--usually the heating element(s).
Aug 07, 2009 | Asko T701 Electric Dryer
Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Mar 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Disabled neighbor was given an ASKO T780 dryer, but it doesn't heat up. What could the problem be so I might be able to fix it for him?
most likely if the dryer does everything except heat up the heating element is bad if you take it apart it will be directly behind the holes inside the dryer
Jan 15, 2009 | Asko T781 Electric Dryer
Asko T731 Electric Dryer Logo
102 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
