Question about LG 81 Bottle Wine Refrigerator - LRV810TT
Lg wine cooler gcw141bxg
I have the lg wine cooler how do i turn up the tempture
What is a build-in wine cooler?
A build-in wine cooler is designed to be built into exiting counter and cabinetry. Build in wine cooler includes a front ventilation system which channels the heat forward from the unit, just like any other wine cooler.
Aug 14, 2012 | Furniture
Tip
Benifits of Wine Coolers & Accessories
Wine Coolers are a great choice for many wine enthusiasts. Wine Coolers & Accessories can be placed virtually anywhere in the home and Wine Coolers offer either a single or dual temperature control zone. A wine accessory is generally any equipment that may be used in the storing or serving of wine.
http://www.jilliandistributors.com/products/wine/
on Aug 16, 2016 | Furniture
Where can I find a wine cooler that has 2 or more different temperatures zones?
there is a wide variety of dual zone wine cooler and theirprices range from around $300 up to $3000 and even more, depends on their and manufacturer. I recommend taking a slightly bigger wine cooler thanintended since once you have your wine cooler you start getting more and morewines and you'll end up with no room...just google dual zone wine coolers
May 29, 2012 | Furniture
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Haier wine cooler freezes the wine.
You may find that the thermostat is not working. Try to turn the thermostat to the warmest setting, the compressor should switch off within two hours, if not change the thermostat.
Mar 09, 2009 | Haier BC112G Wine Cooler
Wine fridge light does not turn off
You may know this already, but for what its worth. There is a small switch on the bottom vent grill for on/off of light. Check there first.....
Nov 27, 2008 | Danby Silhouette DWC512BL Wine Cooler
U-line 15" wine cooler not cooling, but light is on.
If the light is on and no fan or compressor is running then its your thermostat that is bad. Thats the only thing that turns on those parts.
Nov 25, 2008 | U-Line 15WC Wine Cooler
Short maybe?
check voltage on outlet is grounded properly try another outlet
Nov 03, 2008 | Haier BC112G Wine Cooler
Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Dec 31, 2007 | Avanti EWC28 Wine Cooler
LG 81 Bottle Wine Refrigerator - LRV810TT Logo
67 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
