Question about Toshiba Satellite A215-S7422 Notebook
Screen turns black
When I turn the laptop on the screensaver comes on, then when I try to do anything else the screen turns black
  • 2 more comments
  • keith527 Jan 24, 2009
    when im using the lap top it will sometimes just go black i have to reboot to get the screen back
  • nsrader13 Feb 28, 2009
    Out of nowhere the screen just goes black. Usually I have to power off my laptop and re boot it. However just a few minutes ago i was messing with the power saving options and set it to high performance and now when you try to power it on, it goes to the boot menu and then powers itself back off again. I just read something that said Toshiba has a problem with their power saving options and this is the result of it.
  • John Hong
    John Hong May 11, 2010
    Does it do this if you boot into safe mode
  • dukyana May 11, 2010
    Have you installed any new program recently?
    Has this problem only just started?
    Do you have up to date anti-virus?
    Novelist:
  • 117 Answers
Boot up in safe mode if you can by depressing the f8 key. select options to boot with networking. from there if you are able to get on, go to Toshiba's website and download the latest video drivers and bios. Make sure you flash your bios and update drivers then attempt to boot normally. this should resolve your issue. Let me know if that helps, I have another solution if that does not.
Good Luck!
Ruben
Posted on Jul 20, 2009
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
www.tomsguide.com/.../laptop-screen-turn-works-external-monitor.html
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
www.tomsguide.com/answers/id.../asus-laptop-screen-display.html
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
Dec 13, 2015 | ASUS Computers & Internet
Restore toolbar. It did not return when screensaver had been showing and I tried to get back to work again.
Do a hard re-boot, hold down the power button until the lap top turns off. Then re-start and check to see if everything is ok.
Mar 03, 2015 | Dell Inspiron 1100 Notebook
Screensaver set
Hi, go to start- Control panel- personalization. Click here and check if the
screen saver is turned off. It is located on the lower right corner. Click on it
to turn the screen saver back on. This is for windows 7.
If you are running XP go to Start- Control panel- Display. Click on the
display icon and there is a tab that says screen saver. Click here and chose
your screen saver.
Oct 19, 2013 | Acer Aspire One PC Notebook
Computer was on, screensaver is from my photo file - it was running. I moved the mouse to get back to the screen I had previously been on, walked away for a minute, came back, the screen was black. ...
Windows 8 especially and sometime Windows 10 may have a black screen during an update for over 15 minutes with no indication that anything is happening.
Try complete power down by holding the power key for 10 full seconds. Consider unplugging power for a few seconds after that as well.
Re-connect power, press power button to turn on the computer then if the screen goes blank, give it a half hour before looking for another solution... it may come back to you.
Nov 06, 2017 | Sharp LL T19D1-B (Black) 19" LCD Monitor
Computer restarts every time screensaver comes on
try to turn off the laptop, remove the cables and battery, then press and hold the power button for 8 secs. Reinsert the cables and battery and turn on the pc. Observe if the screen saver works...
Aug 03, 2010 | Toshiba Satellite P105-S6197 Laptop
My HP Pavillion laptop just started this. I will get up from using the laptop, and when I come back the screen is black and won't come back. Moving the mouse won't bring it back. HELP!
Remove screensaver and sleep settings. And wait for the same duration. It is goes blank and locks up, report again. Else it is a problem with the screen saver. Change the screensaver and try again
Jun 25, 2009 | Dell XPS M1530 Laptop
No start up page just has screensaver
from the black widows screen, hit ctrl-alt-delete. This will bring up a menu. Choose task manager, the file...run. In the run box type restore. From the box that comes up choose rsttui.exe. This is the windows restore utility. Follow the steps to restore your system, choose a date from before the issue started happening.
May 26, 2009 | Acer Aspire One PC Notebook
Getting frequent black screens on 1501 Inspiron Laptop
Black screen is probably a screen saver or the screen is turned off by power management software.
Check your screensaver setting. Change the screensaver to None to disable screensaver.
I assume you are using Windows XP.
If the LCD is turned off by power management, on the same screen with screen saver, on the lower part of the box there is a Power button. Click to open Power Options Properties. Set your monitor power properties there.
When the screen go blank and you have to push power button, probably the computer is set to go to stand by mode after some idle minutes. You can also set it here in system standby setting.
Regards,
Dapid Candra
Dec 08, 2008 | Dell InspironTM 1501 Notebook
Dell Notebook
It sound like your power settings are turning the screen off. Try the following:
Right click on a the desktop and select Properties and then Screensaver and then click on Power. You will see power settings that tell the computer whether or not to turn off different things at different times. You'll see "Turn off monitor" and a selection next to it. It probably says "after 20 minutes". Change the setting to whatever you want between 1 minute and 5 hours, or Never. Let me know how you did, please grade this.
Apr 07, 2008 | Dell Latitude D600 Notebook
Toshiba Satellite A215-S7422 Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
