SOURCE: power switch on Samsung SyncMaster 740Nw 17... lcd
the leads from your ((motherboard to your hard drive)) make sure they have a secure connections and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions even something as small as an electrical fan and its lead can cause you problems or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard hope this helps you
Desktop or laptop computer
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
replace bad capacitor on power board (like 820/25v or 1000/2v)
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
hope this helps you
