Question about Polar S410 Heart Rate Monitor
Seeing heart rate displayed on my polar compatible treadmill
I have the polar RS400sd. what do i need to do to ensure that my heartrate displays on my polar compatible treadmill.
    New Friend:
  • 69 Answers
If you're looking for a good deal on a heart rate monitor that is compatible with most professional treadmill brands check out: http://www.partsfortreadmill.com/
Posted on Jul 17, 2015
I didnt knwo my treadmill was compatible i just hooked up like i wanted to read from my watch and then both started to read...although the treadmill had a bit of a different reading
Posted on Jan 27, 2009
How do you reset cardio track watch
u may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions
    • 1 Press any button to activate the Polar F11 Fitness heart monitor unit.
    • 2 Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button. There are five buttons and the "Light" button is at the top left side of the unit. Continue to hold the buttons until the display fills with digits.
    • 3 Press the "OK" button, which is located on the right side of the unit in the middle of the up and down buttons. The Polar F11 Fitness heart monitor will reset.
Oct 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
Instructions to reset a nordictrack cardio track watch
You may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions:
    • Press any button to activate the Polar F11 Fitness heart monitor unit.
  • Oct 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
    It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
    First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
    Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
    Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
    If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
    Jan 12, 2011 | Polar F6 Wrist Watch
    No heartrate
    Heart rate hand grips wiring bad or the Heart Rate board attached to the console board is bad.
    Jul 03, 2009 | Life Fitness 91Ti Treadmill
    Inaccurate Measurements of heart rate
    Replace the battery. Then make sure that it is placed on the proper artery that it is supposed to be on. If your heart rate was 210 you would be in the hospital with a heart attack. And also the only person I know with a heart rate of 90 when running is Lance Armstrong. Your heart rate should be about 120 to 135 and it will just around in those areas but should never go higher
    May 22, 2009 | Polar F6 Wrist Watch
    I just bought the Edge 705 with heart rate. I have done everything to get the display of heart rate to come up on the screen but nothing is working. I've tried wetting the sensor on the strap, standing...
    Menu>Settings>Data Fields>Bike Computer #>Press Stick>Select Field where you want HR to Display>Press Center Stick>Scroll to HR>Press Center Stick to select. et voila.
    Mar 24, 2009 | Cadence Garmin Edge 705 With Speed And...
    Heart rate monitor chest band not working with Life Fitness 9500H
    This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
    Mar 12, 2009 | Life Fitness 9500HR Next Generation...
    Polar S410 Heart Rate Monitor Logo
    1,096 people viewed this question
    Top Polar Exercise & Fitness Experts
    Ansel Alberto
    Ansel Alberto
    Jerry Greenberg
    Jerry Greenberg
    Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
