Question about Dometic RM2652 Refrigerator
Check light comes on in gas setting at random times
The fridge will run for different lenghts of time, sometimes a day or two, then the check light comes on and I have to re-set it. Other times it will only run for a few minutes. The fridge works great when plugged in to a/c.
    Habit-Forming:
  • 20 Answers
Make sure you have good hot batteries fridge should be getting 13-14 volts Could be a bad ground unplug them and spray with electric parts cleaner, but most likely the main circuit board is bad. Take the black cover off the circuit board and if it is filled with yellow epoxy it is almost positively the circuit board.
Posted on Feb 20, 2009
2006 Silverado v8 5.3L, check engine light randomly comes on and shuts off randomly. Mostly comes on during rush hour or idle for a long time. Stays on for the day, or 2 days, or 3 days, then might bet of...
Get a diagnostic check before you start guessing and spending money. One of those devices can be purchased for about the cost of taking your car to the mechanic. If you are near an AutoZone they will sometimes check it for free.
Feb 21, 2015 | Cars & Trucks
Engine runs great, everything seems to work but since buying it yesterdday it has just died going down the road 3 different times, then sometimes starts right up and other times it needs to sit a minute...
hi if the check engine light comes on i would start by changing fuel filter or fuel pump, however sometimes sensors dont trigger the check engine light and if it doesnt come on i would pull out the cam and crank sensors and clean them as they maybe dirty and causing the spark to die randomly
Apr 19, 2011 | 1992 Subaru SVX
Fridge does not get cold, lights are flashing and whoo whoo noise
Lights which previously did not flash but now do are clear indicators of operating failure.
Refridgerators and freezers do not like being unplugged for too long. if yours has been disconnected from the power for more than a couple of days, it could be damaged and need part replacement.
The variables are cold leakage, cooling gas leakage, electrical pump failure, thermostat circuit open, thermal cut-off switch disconnected. All of the above can be dangerous - electricity, gas, over-working pump etc. so always remember what we learned in kindergarten - If in doubt don't' - good advice with anything risky.
If you set the fridge on the coldest setting, place a common thermometer inside, note the initial temperature after closing the door for 15 minutes and then leave the fridge door closed overnight, in the morning carefully touch the heat transfer coils at the back, they should be hot all over to the touch. Open the door and check if the temperature has dropped.
If the whoo whoo noise is coming from the pump (often located in a black closed saucepan-sized unit you need to contact a qualified Whirlpool fitter.
If the whoo whoo noise is coming from around the edge of the door, the airtight seal is possibly defective. The seals often get dust etc. trapped in the accordian-like sealing strips around the entire door so, being careful not to damage the seal, clean the inner grooves - an old toothbrush and household cleaner generally work well.
If the fridge is a self-defrosting type, the lights may be indicating that it is stuck in defrost mode - check the Whirlpool website for troubleshooting temperature settings. There is often a small regulator switch which can break down. If you think that this is where the noise is coming from do not go fiddling about - electricity is a to be treated with care. Look for scorch marks or listen for crackling noise indicating a short sparking. Unplug the fridge before poking around the wires. A connector may have been dislodged and needs to be reattached so double-check that the power is off before reattaching the loose wire. It should be obvious where it plugs in but if not, don't go touching different tabs.
Re-read the installation and operating manual or call a fridge repair service if you are unable to find the fault. You can save time and repair costs by telling the repair person what you have tested and the results.
The built-in thermostat could be malfunctioning and preventing the coolant coils to absorb heat.
Sometimes the defrost drip tube can become blocked. This generally runs down the back into a drip tray. You should be able to check for blockage by thoroughly cleaning the tray end of the tube and blowing through it. Don't ****.
I hope this helps,
jenni.
Sep 09, 2009 | Refrigerators
My dometic 2611 dosent want to operate correctly. Check light consistantly comes on. I'mm connected to ac power all of the time. AC sometimes works for a day or so then it might switch to gas for no...
If your unit is automatically switching from AC to gas for no reason, then you either have a problem with the power supply or the lower control board. On the outside of the fridge, there is a black box located in the lower left corner, this box is the control unit. The control unit senses the incoming power source and automatically switches it to LP if no AC power is available.
Turn the refrigerator on and set it to auto. Let it run until you notice that it switches to gas. Immediately go outside and check for incoming 120VAC power at that lower board. If you have power there, then you have a bad board. If you do not have power, then you have a power supply problem. Check the electrical plug and outlet in the fridge compartment and also make sure that your GFCI's throughout the coach are ok.
Hope this helps,
Jeff
Jul 06, 2009 | Dometic RM2652 Refrigerator
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Timer comes on at different hours of the day and night
make sure its set to auto not random. also, make sure you dont have additional times in your setting.
Jun 14, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
Kia Rio 2002 turns over but does not fire
This may be the fuel pump failing, if it is it will strand you some time in the next few months.
Oct 05, 2008 | 2002 Kia Rio
Dometic RM2652 Refrigerator Logo
105 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
