Question about Garden
Wiring problems on cub cadet model 13aq11cp712
Changing kolher v-twin to briggs v-twin
  • 376 Answers
SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Posted on Jun 12, 2009
  • 202 Answers
SOURCE: how do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Posted on Jul 08, 2009
  • 142 Answers
SOURCE: cub cadet repair manual
partstree.com may have then or call the manufacture
Posted on Sep 23, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
Cub cadet 10 50, briggs and Stratton, V twin cylinder, 2011 lawn tractor model 13wr91ap009 serial 1c030h60037. has spark and gas ad air but will not run. It almost idles but then quits.
Hi Lorraine:
If you take the air filter off and squirt in a bit of gas, will it run? If so, the carb is probably gummed up and a good cleaning should get it happening.
Jul 13, 2015 | Cub Cadet Garden
I got a 50in cub cadet ZT came with a Briggs on it . I'm putting a 22 hp Kohler command motor on it. I need the specs for all the wiring from the Kolher command motor to the Cub Cadet
Look at the wiring color codes and their purpose in the Briggs manual, Compare to the wiring color codes and purpose for the Kohler engine in manual, connect accordingly.
Jun 15, 2015 | Cub Cadet Garden
How do I get a Operator's manual for a cub cadet SRS621 lwanmower
mtd cubcadet should have it the model numbers changed allot so you have to be sure and have the right one sorry good luck
Jul 09, 2014 | Briggs & Stratton Briggs Stratton...
Mtd 990 18hp. briggs charging system wiring diagram
you have a stater under the flywheel and a diode if not charging chang diode it is usally the problem
Jun 27, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Valve lash on cub cadet 19 hp kolher engine
have you replaced the starter how old is machjne
Feb 18, 2013 | Cub Cadet Garden
I need a wiring diag for a international cub cadet 782 sn#2050601u725761 mod#144782399 17hp kolher will not charge when blades are on
Here is the wiring dagram for sn's 720000-737624
http://www.cubfaq.com/wiringdiagrams/782a.jpg
Not sure why the problem manifests only when the blades are on.
Battery charging power comes from the white alternator wire on the engine thru the key switch (in run or start position) terminals R to B through the charge indicator and a fuse to a connection on the start solenoid and then to the battery. It does not go through the PTO clutch. The only thing that would make any sense is if there was a chassis wiring harness short that was being made by the position of the mower deck.
Hopefully the diagram will help you find the problem.
Thanks for choosing FixYa,
Kelly
Aug 17, 2011 | Cub Cadet Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
