Question about Canon imageRUNNER 5000 Copier
Canon ImageRunner Scan feature won't connect to network
When I try to turn on the Scan option from offline to online, I get a message that says "Waiting..." but it never goes online.
It's a Canon Imagerunner 5070
Any ideas?
Thanks!
  • itsme13 Feb 05, 2009
    I have the same problem. I have downloaded the scan gear tools, it sees the copier and yet, will not allow me to scan. Frustrating.
  • 168 Answers
Its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Posted on Jan 03, 2009
My canon wireless printer keeps saying offline. I must turn on and off to get it to work.
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
May 31, 2011 | Office Equipment & Supplies
Why is my canon mp495 saying that it is "offline"?
Go to system settings and select the 'Printer' option. Right-click on the printer and enable the 'Use Printer Online' function. Cancel all the printing jobs till that moment and redo the process. Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue. Check all network connections and functions. Be sure the network interfaces work properly. Turn the printer off and on to see whether the device is working properly.
Mar 22, 2011 | Canon Office Equipment & Supplies
CANNON IP100 WILL NOT GO ONLINE
Mar 01, 2011 | Canon iP100 Portable Printer
Now it says offline?
Feb 24, 2011 | Canon PIXMA MP170 All-In-One InkJet...
Scanning question
The Machine must be connected to a network.Download Network Scangear software driver from the Canon webside,install it on your destop.After installation open the Scangear tool and select the discover button.The scangear will search for the machine on the network.As soon as it has discover the machine the ip address will show in the tool.Select the Machine and close the scangear tool.Select the scan button and set it to online.
Now you can scan in to a program like word or exel by Insert a picture from scanner.
Dec 14, 2009 | Canon imageRUNNER 5000 Copier
Ir c3200 is offline
Check that network settings are still correct in system settings. If they are then power down the machine for 10 seconds and restart it. Wait for 10 minutes to see if it comes online. Try pinging it from a pc on the network to see if it can be seen - to help determine if there is a faulty network card in the machine. Pinging means entering the DOS screen and typing 'PING (SPACE) 'IP ADDRESS OF MACHINE' then enter.
You should get some response if it's connected ending with a number like TTL225 etc. Check that there are no error messages on the machine itself causing it to force itself offline.
Nov 09, 2009 | Canon imageRUNNER C3200 Copier
Unable to scan document
try to add your printer so that you can scan, just click start of your computer then go to all program the add printer or scansoft then restart your pc to take effect
Jun 30, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon IR scan problem
Read the Manual (comes with Tool). If you don't have the Tool download it from the Canon site. Go to the copier and press the System/Options button next to Copy/Mailbox/Fax. Press Online. Then try scanning. Go back to copier and press Offline so can photocopy again.
May 27, 2009 | Canon imageRUNNER 2200
False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Scan Function Error
when you open the tool did you use discover or select ip adress unless the tool selecs the scanner it wont work what program are you scanning with scan tool is only a driver you also have to select scan gear tool as your scanner in your program
Feb 05, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon imageRUNNER 5000 Copier Logo
3,477 people viewed this question
old marine
old marine
