Question about Sharp R-930AK Convection/Microwave Oven
Sparks are flying
I turn on my Sharp r930ak and after a few minutes the sparks start flying from the top of oven cavity. Should I be worried? I shut it off manually look inside and can not see where the problem is. Can it be saved? it is several years old and yesterday we had a lost of power that came back on several minutes later. However, we used it yesterday after that power moment. What can I do?
  • Sharp Master
  • 9,149 Answers
This needs to be corrrected. The job of the waveguide cover is to protect the waveguide (opening) and the magnetron from buildup of food particles and grease. When the grease and food particles build up on and behind the cover, they will carbonize and arc - and maybe even flame up! The solution is to clean it and keep it clean - but if it's too dirty or is burned, it must be replaced. Sometimes it's necessary to remove the cover to clean both sides of it, and to clean the edges of the opening it covers. It is sometimes held in place with a small plastic rivet (or screw) and once that is removed, the cover will slide over a little then drop down. Be VERY careful not to get cut on the potentially sharp edges of the opening, and do not spray anything into the opening. Apply an alcohol-based cleaner (such as the purple kind) and /or gentle scouring powder to a cloth or paper towel and carefully wipe it out, then when it's dry, reinstall the cover and the rivet. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Even better, we have the full service manual in PDF format available for download at http://207.234.249.73/mwd/r930ak_aw_sm.pdf It will guide you through the safety issues and give you exploded views and part numbers in case you need to order parts, which you can get at Tritronics at http://www.wehaveparts.com
Posted on May 13, 2007
REPLACE WAVEGUIDE COVER. MAKE SURE CAVITY AREA IS CLEAN,
Posted on Jun 12, 2007
When the unit is turned on it shoots flames from the roof of the unit WHY?
It sound like the antenna behind the plastic plate may be warped and touching the cavity. From my experience when they start shooting sparks it is time for a new microwave.
Apr 23, 2015 | Sharp R-820BK Microwave Convection Oven,...
Sparks when cooking
Make sure no metal item (forks-spoons or oven rack) is touching the outer wall of the microwave. That will cause sparks. If all that is OK then there is usually a metal fan type blade in the microwave top called a stirrer blade that may be out of place and rubbing the cavity causing sparks. Try to pin point the spark area so you know where to look for the problem. Sparks usually mean metal is touching metal somewhere.
Mar 29, 2015 | Whirlpool MH7135XE Microwave Oven
Can I fix a microwave oven that sparks when you turn it on? on Model JRS1130DSBB?
Generally once they start sparking it is the end of the microwave. If they are sparking in the cavity sometimes cleaning the cavity thoroughly will stop this. If it is in the wave guide. there really is no fix.
Sep 27, 2014 | GE Microwave Ovens
My Goldstar MV-1310W microwave has sparks flying from the metal plate that's inside on the top.
Microwave ovens do not work well with exposed metal. IF you place uncoated metal in the oven, sparks will occur.
IF the interior of the oven has the metal exposed, it will cause sparking to occur.
There must be NO exposed metal inside a Microwave oven!
Aug 15, 2011 | Goldstar MV-1310W/B Microwave Oven
The enamel is wearing off where the back side meets the base on the inside of the oven. No sparks are flying but is this repairable? Emerson MW8775W Microwave Oven
Small areas inside the cavity can be repaired. The bare spot must be very smooth. You can sand it down if needed and then repaint. There is a m/w cavity paint sold in a spray can, but I've had really good luck using regular appliance touchup paint. Just be sure the spot is very smooth when you finish. Use several thin layers of paint instead of one thick layer and you should be ok.
Dec 28, 2010 | Emerson MW8775W Microwave Oven
My sharp microwave oven sparks and pops when in use.
1. You have to clean m/w inside from all kind of grease and food resedue.
2. Inspected m/w cavity inside and clean all burning spots with sand paper.
3.Apply touch paint on this spots.
Different color touch paint you can buy at any appliance patrs store.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 01, 2008 | Sharp Microwave Ovens
Microwave started sparking and making noises a few seconds after its turned on. The sparks are behind a white colored rectangle in the right wall of the oven. Can anyone please help.
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Aug 06, 2008 | Sharp Microwave Ovens
Sparks fly when I use my microwave!!!
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 11, 2008 | Frigidaire FMV156D Microwave Oven
Dacor Microwave
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
The part would be much cheaper if you get the Sharp version (these ovens are made by Sharp) instead of the Dacor branded part.
The model DMT2420 is essentially the same as model R440D / R540D.
The Sharp part number is PCOVPB085MRP0 (zero on the end) and you can order Sharp parts from Tritronics at http://www.wehaveparts.com
Mar 17, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Sharp R-930AK Convection/Microwave Oven Logo
147 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
