Question about Fujitsu LifeBook Computers & Internet
My fujitsu lifebook v series (model no: v1020) monitor/screen went black. Actually when i start my laptop, it is working perfectly but after 10 or 15 minutes screen block. In this situation laptop is running perfectly but screen is black. After when i restart my laptop after few minutes am facing same problem If any one know about this please help me my email: srikanthkudikala3@gmail.com
eagle338
  • 4889 Answers
SOURCE: Password Bios
Ok.. Irrespective of any model or brand the BIOS password reset is very simple. The BIOS settings is remembered with the aid of a small Lithium battery. Pull it out wait for 30 seconds and put it back in and all the BIOS settings will be back to default!
Please dont forget to rate the solutions.
Sai.
Posted on Mar 23, 2008
ginko
  • 19396 Answers
If your computer is showing no splash screen or any prompt from bios, only black screen on startup. Then you damaged bios using the program FSC-BIOS-WINDOWS. In this case only solution is tekeing the laptop to a service center, so that they can have your Cmos chip re-flashed using an external device.
You can also try running your recovery disks on startup. If the bios is damaged, then it will not boot from any support, including your recovery disks.
If your problem is just to reset the bios password instead, then you need to open the laptop and bridge a little contact on the motherboard, or remove motherboard battery temporarely. Here is lifebook service support from Fujitsu.
http://www.fujitsu-siemens.co.uk/rl/servicesupport/techsupport/lifebook/index.html
If you cannot do it yoursef it should be done in any service shop for a not-too-expensive charge.
regards
Posted on Mar 25, 2008
hokuwho
  • 306 Answers
SOURCE: win 2000 on fujitsu siemens lifebook b-series
  • Boot to the xp cd
  • After the setup installs then it will ask if you want to install xp, repair or install to another partition.
  • Choose install and the install program will say that it is inspecting and looking for previous Windows.
  • The dialogue will now say that a previous Windows is installed and to choose whether you wish to install on the same partition -you do not, delete that partition -you do. I think it is "D" to delete, then "L" on the next Window.
  • When you see the next screen it will list the partitions. Notice the "unpartitioned" disk space -that is where you want to install the new Windows.
  • It should be all or most of your hard drive space. If there are other partitions delete those as well unless there is a relatively small partition, say 4 or 8 gigabytes partition that may have information stored for the hard drive itself to use for it's own purposes.
  • When you have the unpartitioned space maximized by deleting the existing Windows you be asked if you want to format the drive in NTFS, Fat32 or leave intact or quick format.
  • Choose NTFS, full format (slow) and let the format begin.
  • When complete it will reboot automatically or you can reboot yourself.
  • After reboot the Windows driver load and inspection will repeat but this time you will have a formatted partition. Choose that for your new install of Windows. After that is complete reboot to your hard drive, not the cd. You can remove the cd if you want to make sure you are booting to the hard drive but the new Windows installation may ask that you reinsert the cd as it loads drivers and so on. At this point have any other cds available for installing drivers for printers, video cards, network adaptors and so on. If you do not have them then download the Windows 2000 drivers to a thumb drive or cd before you do this install.
  • Windows has program compatibility program that inspects or lists what devices might not be compatible with Windows 2000. Also the manufacturer can tell you what Windows versions they can support. Here is a comprehensive list of Microsoft downloads for Windows 2000. Make sure that you have service pack 4 downloaded to cd or thumbdrive.
  • http://www.microsoft.com/downloads/results.aspx?pocId=38DF6AB1-13D4-409C-966D-CBE61F040027&freetext=2000&DisplayLang=en
  • Take you time and let me know if there are any problems encountered. I am certified for Windows 2000 Pro OS and networking. ~Steve Medley
Posted on Nov 10, 2008
  • 8 Answers
SOURCE: i have a fujitsu C series lifebook and my display
It's problem of the LCD converter, it's easy to replace. Take out the four screws at the corners of your screen (they are covered by rubber footing or a sticker), carefully take off the bezel, you should see a 6 inches long some sort of circuit board just above the keyboard, at the bottom of your screen. That's the inverter, check the model number and search for it on eBay, it's usually about $15 to $30 bucks. Replace it, and everything should back to normal.
Posted on Apr 08, 2009
SOURCE: Fujitsu Siemens Laptop loose screen
some hinge screws are under the power button bar,over over the keyboard,also in back or under the unit where the lcd is located
power button bar is also the hinge covers this pops out , but may be screws on bottom holding it
Posted on Jul 20, 2009
Fujitsu lifebook black screen
Sounds like a bad connection. You will have to open the laptop and verify the connections, front and back of the screen. The ribbon cable behind the screen can sometimes lose contact causing that issue. A bump, drop, jar, will cause the connections to come lose a bit. Use a Can of Electronic Contact Cleaner spray to clean the connections and reseat. If you don't feel comfortable opening the Laptop, take it to a Qualified Computer Tech. Have you connected it to a External Monitor to verify the Graphics Adapter is working correctly?
Jun 05, 2013 | Computers & Internet
Please help solve my driver problem for Fujitsu lifebook v1020...thank so much
If you use your laptop to surf web , office stuff, movies , music , there are some games that works, try to install ubuntu 12.10 , works great for my laptop , i didn't have to install any driver :) ,kernell took care of everything . Sorry for my bad english :)
Feb 01, 2013 | Fujitsu Computers & Internet
My Fujitsu-Siemens Lifebook S7110 display going black time to time. It's coming back after restarting and it's working great with external monitor.
The display may be going black because of IC's getting heated up,contact ur Provider and get the screen replaced if using an external monitor is irritating
Dec 20, 2009 | Fujitsu Siemens LifeBook S7110 Notebook
Black screen when turned on
first thing you do is to change the RAM (memory). if still black screen, you have to re-install or format again the laptop.
Aug 15, 2009 | Fujitsu LifeBook A3130 PC Notebook
Fujitsu Siemens Black Screen problem
Hold the power button in for a few seconds, until it powers off. When it reboots, change your power settings. Don't shut the monitor off after any time span, it isn't necessary.
Aug 08, 2009 | Fujitsu Siemens LifeBook T1010 Tablet PC
Please solve My problem-fujitsu V1020 Lifebook formated Vista then setup windows XP P2. sound detect but show message Error Code and PCI not detect.help me please.thanks
you cant able to the vista sound to xp the driver the company will give you only vista driver cd so get the sound drive for xp - download more than 3 diffrent sound driver for your pci slot realtec audio from internet and install it and it may works.
Jun 10, 2009 | Fujitsu LifeBook Notebook
Fujisu lifebook problem.
Most likely a hardware issue already as how you described it. So your fan is not working? Your system is heating up already. It might also have gotten some damage on the video as well. You have to get someone check the hardware locallly.
Jun 02, 2009 | Fujitsu LifeBook C6631 Notebook
External monitor on Laptop not receiving a signal
When you start your computer, keep hitting the F8 key. you will get a menu that comes up.. Choose the VGA mode.. this will stop the computer from loading video drivers and will allow you to install the new monitor.
Give that a try.. Hope it helps... let me know
May 31, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Display problem in Fujitsu LifeBook C Series(c-6631
the internal bulbs of ur monitor screen have deteriorated...the manufacturers are real smart, these monitors dont last forever. So if repair estimate is too expensive then replace the whole unit.
Always purchase laptop or notebooks NEW or never more than 5 years old.
May 24, 2009 | Fujitsu LifeBook C6631 Notebook
Computers & Internet Logo
67 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
