Not spinning The gear not engaging for spinning
    Problem Solver:
  • 5 Answers
First of all is the washing machine is empty, Then check the lid switch which is sometime a mercury switch and it's associated 2 wires. And if it is a mechanical switch be sure it is closed when the lid is closed (top cover panel).
Posted on Oct 25, 2012
    ???? ???? Oct 27, 2012
    The gear not coupling with motor to turn the spining drum
Kawasaki starter not engaging
Hi, Ricky the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starter spins but engine does not crank
Starter spins but doesn start the bike Ex 500 com The home of the Kawasaki...
Starter spins but doesn turn the engine
Mar 22, 2017 | kawasaki Motorcycles
Kawasaki bayou 300 starter spins but wont engage all the time
The larger idler gear ring was spinning but not spinning the entire gear. I couldn't figure ... Starter Idle Gear Limiter Kawasaki Bayou 220 250 39076 1060 ' eBay ... kawasaki bayou 300 starter will not engage.
Mar 21, 2017 | kawasaki Motorcycles
The starter motor will not engage
Hi, Paul the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day. Starter spins but doesn turn the engine
Starter spins but won catch
http://www.apriliaforum.com/forums/showthread.php?189764-starter-spins-but-doesnt-engage
Inside look of starter spinning but not engaging
May 15, 2016 | Motorcycles
Any adjustment for hino dutro tipper pto.
When engaging the pto it is important that you have the clutch disengaged so that the pto gear is not spinning in the box.before it engages.
The pto gear runs off the counter shaft of the gear box and is spinning all the time the engine is running
when engaging the pto ,you are physically engaging a gear ( like selecting 1st gear) so you have to stop the counter shaft spinning so that the pto gear will engage with slashing
Jun 14, 2015 | Garden
1999 Honda F6 C Valkyrie starter spins but won't engage
Hi, Anonymous the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
starter spinning not engaging flywheel Honda Tech Honda Forum Discussion
1999 GL1500 starter won engage GL1500 Information Questions goldwingdocs...
Honda GL1500 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1997 GL1500C Valkirie Owner Manual
Jun 25, 2014 | 1999 Honda F6 C Valkyrie
Starter just spinning,not engaging
Hi Anonymous, if you are talking about the starter drive gear the insides have some type of components that centrifugal forces them to grab or lock into permanently fixed counterparts. Never had one apart but the gear only spins one way and locks the other way. If you have one that spins both ways it has failed and needs to be replaced. Good luck
Aug 04, 2013 | Harley Davidson FLSTF Fat boy Motorcycles
Starter spins, but,will not engage,same as the one i repaced
You need to check for worn or broken gear teeth on the flywheel ring gear.
Mar 06, 2013 | Cars & Trucks
I have a 1999 Gilera Runner 180FXR, New bat 12V 9 amps. Starter turns and spins pinion gear but won't engage starter ring. If it does it turns ver slow or won't turn engine over. In manual it
Yep, not enough amps to engage the starter clutch, and when ti does engage, not enough amps to turn the engine. You need a 12 amp battery.
Nov 17, 2012 | Motorcycles
What going on
Bad switch or Solenoid. depending on the bike.
Mar 17, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
