Question about Canon Office Equipment & Supplies
Canon IRC 3220 showing the error code E000602-0301
HELLO HELP ME MY CAR EVERY DAY POSTER 3220N CANON IRC ALWAYS START THE FOLLOWING MESSAGE error code E000602-0301
  • 11 Answers
SOURCE: Canon IRC 3220N
Press *, then press 2 and 8 at the same time ,then * again
Posted on Oct 28, 2008
  • 199 Answers
SOURCE: Canon IR 3300 switchs on it displays the Erro E000602-0003
replace hard disk drive
Posted on Feb 15, 2009
SOURCE: Error code E000070-0003
checkpoints...
1)check for itb assembly grounding
2) white patch inside itb
3) secondary transfer roller rotation
4) variastor at registration assembly
Posted on Apr 25, 2009
komguy
  • 2306 Answers
SOURCE: how can fix the problem with my canon mp 190
That error is telling you that the ink absorber inside is full. You need a shop to replace that because you need to use Canon diagnostics to reset the error code.
Posted on Jul 21, 2009
  • 1335 Answers
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
Posted on Dec 19, 2009
Canon iR 3220n colour photocopier error code E000020-0481
The path between the sub hooper and the developing assembly is clogged with toner.may be a developing assy.toner sensor failure,or the sub hooper toner sensor
Jan 23, 2015 | Canon Office Equipment & Supplies
What does error Code E000732-0001 on a Canon irc 3220 error code mean?
Hi Bob Smith,
Error Code E000732-0001 is a reader board error. Please check all your connection on your printer if there is a unplug connection connected to a device. Or just unplug and plug all the connection on your printer.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Xerox WorkCentre PE16 All-In-One Laser...
E000012-0001
Thread irc 3220 error e000012 0001
Your ITB unit (Intermediate Transfer Belt) may need changed. Try removing it first and rotating by hand.
If it sticks, you are probably looking at a new unit.
The link above is for the iRC3220 but Canon codes are generally all the same.
You may find there's a tear in the belt and this is why it is not working properly.
Mar 28, 2014 | Canon iRC3100 Printer
IRC 3220 Color Copier when printing pdf files is very slow. A 2 page document takes 2 hours to print. please help.
Hello pd.
I suggest you remove and re-install your print driver and make sure you install the CANON UFRII print driver available at the Canon web site. Also, Adobe 8.0 has a known problem with this and you can go to their website and they have a patch for this problem, I hope this helps.
Feb 16, 2011 | Canon imageRUNNER C3220 Color Copier
Canon irc 2100 showing the coad # E020-02A0
The Magenta drum unit needs to be replaced. Good day
Nov 06, 2009 | Canon Office Equipment & Supplies
CANNON IRC -2880
this code is for a bad OHP sensor, wich detects transprerencies.
Aug 19, 2009 | Canon IMAGERUNNER 2230 Copier
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
ERROR CODE E00002-0102
You have a fuser problem. You didn't specify a machine but if it is the irc/clc3200/3220/2620 you will need to replace the fuser unit. If you have a different model where the fuser thermistors/thermal fuses etc can be replaced then replace according to the manual.
Canon Copier Sevice Manuals
Oct 25, 2008 | Canon imageRUNNER C3200 Color Printer
Canon IRC 3220N
Sep 01, 2008 | Canon imageRUNNER C6800 Copier
Error code Canon IRC3200
change the black drum reached end of its life
Canon Tech
Jul 22, 2008 | Canon imageRUNNER C3200 Copier
74 people viewed this question
old marine
old marine
