Question about Acer Aspire Z5600 PC Desktop
My acer z5600 won't turn on
Won't turn on
    Sergeant:
  • 247 Answers
First be sure the power cord is fully seated. Press and hold the front-panel power button for 5 seconds (just in case it is in a hung state).
Then follow these instructions from the user manual at http://support.acer.com/acerpanam/Manuals/acer/2009/UserGuides/AS_G_En_V09A1.pdf
Q: I pressed the power switch but the system did not boot up.
A: Check the LED located above the power switch.
If the LED is not lit, no power is being applied to the system. Do any of the
following:
• Check if the voltage selector switch located on the rear panel of the
computer is set to the correct voltage.
• Check if you plugged the power cable properly into an electrical outlet.
• If you are using a power strip or AVR, make sure that it is plugged in and
turned on.
If the LED is lit, check the following:
• Is a non-bootable (non-system) diskette in the floppy drive? If yes,
remove or replace it with a system diskette and press Ctrl + Alt + Del to
restart your computer.
• The operating system files may be damaged or missing. Insert the startup
disk you created during Windows setup into the floppy drive and
press Ctrl + Alt + Del to restart your computer. This will automatically
diagnose your system and make necessary fixes. However, if the
diagnostic utility still reports a problem, then you may have to perform
the recovery process to restore your system to its original default factory
settings.
Posted on Oct 25, 2012
3 Suggested Answers
samaddar07
  • 639 Answers
SOURCE: i have an acer aspire z5600-U2092 all in one pc
SYSTEM RESTORE Windows XP
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Posted on Oct 18, 2011
  • 27 Answers
SOURCE: My CPU fan is running really fast and my pc ( acer
you will have to send it in to be repaired it sounds like the hard-drive needs reseting it happen to me on my acer x3200 i got it from comet bad move as they will not replace anything not unless then manufacture say so. It want back to them 11 times
Posted on May 09, 2012
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
Black screen on acer aspire Z5600
this can occur due to faulty RAM also or reset the bios to default settings
Jan 30, 2013 | Acer Aspire Z5600 PC Desktop
Are Acer z5600 dvd players multi-regional?
Open the properties of the DVD/CD rom, Hardware Tab, select DVD/CD rom device, Properties, DVD Region, select Region. READ CAUTION CAREFULLY.
Dec 26, 2012 | Acer Aspire Z5600 (AZ5600U2092) 23 in PC...
Are acer z5600 dvd players multi-regional?
You can switch the region manually but it will lock out after few switches. Use this utility to do without this problem.
http://www.digital-digest.com/dvd/downloads/showsoftware_remote_selector_433.html
Dec 26, 2012 | Acer Aspire Z5600 PC Desktop
My Acer z5600 just shuts off while I'm doing something without any notice.I gets very hot at the top of the screen and then shuts off without warning.The screen just goes black and I can not turn
Your processor is overheating. Or the fan for the CPU is dead or the way to eject the warm air is blocked. Try to work with your laptop on a table, if the problem persists, is the fan other way you have to work everytime on the table.
Aug 06, 2012 | Acer Aspire Z5600 PC Desktop
Power button not turning computer on
this is most likely a short in a computer component, You need to unplug everything from the computer incl CPU, Memory, Add on Cards, Hdds, the lot, just have motherboard plugged in and push power, if it powers up (there won't be a pic but you will know it's working) start replacing parts one by one until it won't start and that is the faulty part. If it does nothing with just motherboard plugged in the motherboard is at fault and needs to be replaced, If you have had the motherboard out make sure no of the metal mounts in the case are shorting out anywhere under the motherboard as this will also cause the same fault.
Mar 06, 2012 | Acer Aspire Z5600 PC Desktop
I have an acer aspire z5600-U2092 all in one pc desktop, but my problem was when i bring it home here in the philippines on the first week i can still use it but it happens on the next day when i want to...
Oct 18, 2011 | Acer Aspire Z5600 (AZ5600U2092) 23 in PC...
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire Z5600 PC Desktop Logo
681 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
