I see your point. But if I decide to place an SSD hard drive, will Windows 7 recognize the other hard drive which is not SSD? Please respond ASASP
  • 2,878 Answers
Windows should not discriminate one way or the other. Just make sure both drives appear in BIOS first.
I guessing you want the OS on the SSD? Load it first, then treat the 750GB SATA as a secondary hd. Just a suggestion if it gives you problems.
Posted on Oct 25, 2012
4 Suggested Answers
SOURCE: Hard Drive with password protected.
I had the same problem. This is how I reset my password on a compaq or hp nc6320.
1. unplug the power cord
2. unplug the battery
3. take two screws from the ram cover on the back of the laptop (see youtube for this step)
4. open the keyboard
5. unplug the cmos battery cable (very easy to do)
6. plug power cable and turn on the laptop
7. laptop would erase passwords.
8. put everything back together.
A pleasure to help.
Javier Blanco
Posted on May 16, 2008
SOURCE: I am installing an Intel
I also use ubuntu on my desktop pc ..you can try the windows xp sata version ..-->HERE!
it is a torrent file ...you need to download and install bittorent .
After you download the iso file ,burn it to a dvd ,and then try to boot it onto your acer notebook .
Posted on Jan 15, 2011
joelwilcox
  • 1274 Answers
SOURCE: IBM Thinkpad G40 not recognizing replacement hard drive
my recommendation is to format the drive and see if that helps. do it via usb.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Posted on May 06, 2012
Can't install windows 8 on a Samsung MZ-7TE120BW SSD drive
When you are starting the new install, Windows asks for drivers, point to where the drivers are located.
Apr 21, 2014 | Samsung MZ-7TE120BW 120 GB 2.5" Solid...
My SSD (ata ts256gssd720) is not recognized when I try to install win7, I had ubuntu earlier (only ubuntu from the beginning)
When you say "not recognized", do you mean that the drive does not show up under "My Computer" with a drive letter? Or that the OS does not even know the drive is there? It is possible that the SSD was formatted using an Ubuntu-specific file system that Windows does not recogize. In this case, the drive may be seen as "Not Activated". To check this in WIN 7, click on START, then right-click on COMPUTER and select MANAGE. When the Computer Management window appears, under STORAGE, select DISK MANAGEMENT. Wait for the window to populate, then scroll down looking for the SSD in the list. It should list a disk number, size, and status of the drive. If it is not ONLINE, then there is a problem. You will probably have to initialize it, partition it, and format it to have WIN 7 see it. Be advised however, that this will remove all data previously stored on it.
Oct 30, 2013 | Transcend Computers & Internet
I was running windows 8 and having trouble with it. So I decided to go back to Windows 7 pro, when doing this I inadvertently put the windows 7 on my second internal SSD drive. now computer is...
Hmm..interesting, so let me get this straight:
You have 2 drives, C drive with Win8 and SSD drive with Win7?
You want to revert back to only having one OS on one drive?
Why can't you just erase everything on the SSD drive? I thought you already had Win8 on that drive? If you don't have anything that you need to keep on the SSD drive, I would just format it and start fresh. Although you always want your OS to run on the SSD drive so that your machine will boot up faster.
Oct 19, 2013 | Computers & Internet
Trying to start computer with SSD and HDD, NOT happening!
Have you tried going into the bios to see if the ssd is recognized and have the computer boot from the ssd So connect the drive and put your windows disk in and install to the ssd During the install it will scan for drives and ask which drive you want to install on Make sure you check the boot options in the bios to allow the connect drive
Nov 23, 2012 | Computers & Internet
I think my hdd is broken, windows does not recognize it.
I have the same problem. It's too late, I know, Diego, but I found this silly solution that I am posting that might work for others. Plug the Toshiba HDD into another USB Port: (Probably Windows OS retains each stream that it has started, and these streams need to be deleted, in the same sense that some apps won't open the file it has open currently.) I read in another forum that the computers USB ports had been fried after a power surge!
Might work for someone.
Jun 11, 2012 | Toshiba HDD2H92) 500 GB SATA Hard Drive
Cannot install whs on ssd using flash drive
I would suggest cloning the OS install.
Install the OS on the 80GB SSD with the Foxconn board that is giving you troubles with the 40GB SSD. Then clone the drives and swap SSDs.
WHS 2011 probably will throw up a flag stating that it needs to be reactivated because of hardware changes, but it should go smoothly.
Dec 23, 2011 | Foxconn (M61PMP-K) Motherboard
HOW TO IMPROVE THE SPEED IN WIN7
The best way to speed up W7 is to install an SSD (Solid State Drive), such as one of these drives:
http://www.compusa.com/applications/category/category_tlc.asp?CatId=5298&name=Internal-Solid-State-Hard-Drives&
While they are expensive, you will_not_ regret the investment. To save $, you don't need to purchase a large SSD drive. Put W7 on a small capacity SSD (commonly referred too as a boot drive) and then use a regular hard drive (your old one) for mass storage. For example, on my computer, I use a 40GB SSD for W7 (C:) and a regular 500GB hard drive (D:) for music, videos, large downloads, pics, etc.
There are also a plethora of websites that will show you how to speed up W7. Here is one:
http://www.computingunleashed.com/speed-up-windows-7-ultimate-guide-to.html
Another way to speed up W7 is to install more memory, but you won't get near the noticeable performance increase as an SSD. In fact, after installing an SSD, if you try to enable ready boost on a flash drive W7 will tell you that it is not neccessary because you already have an SSD that is faster.
Feb 06, 2011 | Computers & Internet
Just bought a new cpu, put it together and purchased the western digital 160 gb sata II model number WD1600AAJS. i am installing windows 7 on it, or attempting and it won't recognize the drive. it says it...
The drivers are not needed, West. Digital is right. Your problem is that the hard disk is not recognized by the motherboard (not the cpu). Since you didn't mentioned anything about motherboard's brand / model, I have to tell you that you have to get into the bios settings and get yout hard disk recognized by the bios. I assume that the connections are right.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 19, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
