Question about AEG 24 in. Favorit 80800 Free-standing Dishwasher
Problems disconnecting the wastepipe on an AEG Dishwasher
We have a smell coming from an AEG This is an AEG 80800 Sensor Logic dishwasher, and water is coming back up through the waste pipe and is sitting in the machine. I have been trying to disconnect the waste pipe from under the appliance - but I have been unable to disconnect. The waste pipe seems to be connected to the underside, but there doesnt appear to be a release mechanism. The machine is quite old I would estimate 8-10 years.
Pour some bleach into the stinky backwash. I know that this is not good for the environment but it will take the stench away while you get a new dishwasher. Sorry but you have plumbing problems out of my range.
Posted on Oct 25, 2012
SOURCE: AEG DISHWASHER, DOES NOT HEAT WATER.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
Posted on Dec 09, 2008
SOURCE: AEG 60830 Leak prevention system
Just pulled machine right out, tipped it over on the side, couldn't see anything obvious or a way "in", so re-positioned it - switched on - error message gone and all working fine !!?!
Posted on Feb 18, 2009
57 varieties
  • 1653 Answers
SOURCE: Horrible smell coming from the washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Posted on Sep 10, 2009
joe_lishman
  • 192 Answers
SOURCE: Recurring .30 fault on AEG dishwasher. Have tried
This is caused by the Anti-Flood device at the base of the machiene being activated. This device detects water leaks and is a polystireene float / micro switch that puts the machiene in pump out mode only. You need to determine where the leak comes from (pipe or perforated hose pin hole or pipe clamp etc.) If you tilt the washer and some water comes out from the bottom it is a clear indication that there is a small leak.
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: AEG Favorit 50730 Dishwasher
The dishwasers have heat (inductive) elements in line with the top sprayer hose and is about +/- 15 cm long and has an electrical push on clip at the side of the device.
How to fix anti flood error on F60860
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Sep 28, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Aeg favorit 40740 sensor logic dishwasher Not heating up
FYI: I ran in a similar situation with my Ikea dishwasher last week.
It started did some stuff but ended early and cold.
In the end it was just because I forgot to refill the soda.
The drain was all clogged together. A quick cleaning fixed my problem.
Only afterwards of course I noticed that an LED was on and there where some white deposits on the dishwashers lid. There was also still some water when I opened the dishwasher.
When I was reading about similar problems, it also happens often that some solderings of the relay go bad. A more or less practical person can check and solve this rather fast. (Because I didn't notice the clogged drain at first, I verified mine in let's say well below 30 min, they seemed fine)
I hope you get your problem solved.
Oct 19, 2013 | Dishwashers
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
AEG Favorit 8081 displays error F0 - there is a build up of dirty water which has not drained way. I syphoned all the water away and after a while the dishwasher started to work again - but then the...
Hello. When the water does not completely drain away, it usually means that there is a partial blockage in one of these areas:
1. The small drain pump located under the tub, accessable by removing the lower front panel.
2. The drain line going from the DW pump to the plumbing under the kitchen sink.
3. The garbage disposal, or the trap under the sink.
Check these out and you will find a chunk of bone, or glass or some other debris which is partially blocking the draining action. J.
Sep 04, 2010 | AEG 24 in. Favorit 80800 Free-standing...
What will a new pump for my dishwasher cost me? Or should I just buy a new one?
you can check out the prices of new pumps very easily by following this tip.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
If you need to have it installed you will have to find someone in your area to call and get a quote, labor prices vary greatly in different areas of the country.
Heatman101
Feb 02, 2010 | AEG 24 in. Favorit 80800 Free-standing...
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
Nov 09, 2009 | AEG 24 in. Favorit 60870M Free-standing...
Panel lights started to flash & F3 appeared in dislay. Made a buzzing sound that would only stop when turned off at the plug
I copied one of the solutions to a problem that appeared on your web site. Pulled the dishwasher out, ladeled water out of the salt reservoir, tilted the machine at 45 degree angles backwards,forward and sideways then poured boiling water into the salt resrvoir, left it to stand overnight, it was working as normal the next day.
Thanks to your website I have saved the cost of a call out and repair bill.
Oct 25, 2009 | AEG 24 in. Favorit 80800 Free-standing...
Code: C 2 ??
C2 error code means, that the drain is clutched.
Removed all dishwasher water with a cup.
Added a gallon of boiled water, waited 10 min and it worked again( so far).
Regards
Sigurd
Jan 28, 2009 | AEG 24 in. Favorit 80800 Free-standing...
Sep 25, 2008 | AEG 18 in. Favorit F54850 Slim-Line...
AEG 24 in. Favorit 80800 Free-standing Dishwasher Logo
180 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
