My mdhd500-n won't connect to new router because it's on a different subnet how do I change it.
I had new virgin media broadband installed last week and now I can't get my network harddrive to connect as it is apparently on a different subnet.. and because it is on a diffferent subnet discovery tool can't access it either .
Guys, I have never used a site like this before & sorry to sound dim but if i reset the drive will it erase the data?
Posted on Dec 23, 2012
  • 2,878 Answers
The hard drive may still have an old IP address. Set your network hard drive to DHCP. Make sure the IP clears and it is on the routers IP subnet. Just ping the router
Go to Start > Search (Run in XP) and type cmd ENTER. In the command prompt type ipconfig /all ENTER.
Posted on Oct 25, 2012
luiskiev
  • 144 Answers
SOURCE: How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Posted on Nov 07, 2008
SOURCE: Buffalo WHR-G54S & Virgin Media
Just to let you know if you havent solved it yet, i had this same problem today and i fixed it by pressing the reset butoon on the modem, this was after hours of trying to reset the router
Posted on Jun 01, 2008
Coldcut
  • 1554 Answers
SOURCE: Wired connection is fine but cannot get internet access - virgin media
Connect the routers Wan connection to the modem
Posted on Jan 26, 2008
SOURCE: belking54g router problem
update the firmware. go to http://192.168.2.1/index.stm and download the newest version
Posted on Apr 11, 2008
SOURCE: 11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Posted on Aug 30, 2009
Connect tv to network
Get them from the net gear router if you can.
Or one of the PC's connected to the network.
the subnet and the router you need will be identical to that of the PC.
the only change you need to make to the IP address is to make sure that the last octet is different to all others on the network.
The IP address is made up of 4 octets. looking something like 192.168.1.28
or similar. In this instance 28 is the last octet.
DNS is not required for this setup.
Nov 19, 2013 | LG Televison & Video
Can I use Belkin 802.11g Wireless G Range Extender with virgin broadband?
This is a highly technical question. The technician that installs your fios can help you with an answer. If i'm not mistaken your new fios will come with a special router designed to change the data your recieving to acceptable format and communicate with your other devices. As I stated the tech who installs your fios can further instruct you as to the exact configuration. Hope this helps.
Sep 02, 2012 | Computers & Internet
Unresponsive wireless broadband virgin media
please login to your browser via 192.168.1.1 and change the wireless channel to either 1 or 11.
also if your wifi encryption is set to WEP please change it to WPA2 or WPA.
Feb 22, 2012 | NetGear WGR614 Wireless Router
My Netgear router has just been replaced by Virgin Media with a DLink 615. The installation disc won't work, so can a connect without it? I'm running on XP and using Firefox as my browser cheers
You will need to reset the router to factory defaults before you can connect to Virgin Moble there should be a reset button on the back of the router press and hold for 30sec. and then reboot it
here is a link to help you setup the router
http://support.dlink.com/emulators/wbr2310/
If you futher assitance lt me know
Aug 31, 2011 | D-Link DIR-615 Wireless Router
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
Doesn't work with windows vista
1. check if there are lights on the specific router port where you have connected the Vista (e.g. if it is on port 2, check if there are lights on #2 at the front panel of the router).
2. check the ip address by going to command prompt (click start-run-type cmd press enter. on the command prompt, type ipconfig/all)
3. ip address should be similar to what your Windows XP is getting. Subnet mask, gateway, and DNS servers should be identical.
Eg. If XP has a 192.168.1.100 IP, your Vista should have 192.168.1.x IP address where x is a variable number other than 100.
4. If your IP address, subnet mask, default gateway, and DNS seems aligned for both PCs, check your browser settings. Open IE, go to tools, internet options, network connection and make sure that never dial a connection is selected.
Jan 16, 2009 | Microsoft Broadband Networking MN-500...
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
Cannot finish connecting
Hi fozzy211 - Please don't rate this 'til were finished. You've got two things going on. You said it's telling you to check the cables and then you say it's saying the router isn't from Verizon. Is it both? Are the cables hooked up correctly to your knowledge? We can fool Verizon's system. Let me know if you actually have two problems. For now I would only hook up one pc via wired until it's working. I'll await your response. Thanks.
Jeff
Jun 04, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
