Question about Roland Mc-909 Sampling Groove Box System
Mc 307 damaged memory
My roland mc307 has damaged memory. screen lights up but thats it. can i fix the problem? how?
  • Anonymous Jan 25, 2009
    this is happening on my xp -50 also
  • Anonymous Mar 22, 2009
    My screen lights up but thats all
My spd20 pad skin is damaged so i want get a new skin ???
Hi.
You need to order the pads skins directly from Roland.
The local Roland number is written in user manual.
Here the service locator in US. If you are based in the USA you can also order the skins from your local authorized Roland Service point.
Here Roland US support contact.
In UK see:
Oct 25, 2010 | Roland Spd-S Sampling Percussion Pad...
How to reset my roland spd-s
You can reset Roland SPD-S by using Roland SPD-S utility CD supplied with product.
If you can't locate (or lost) the CD that is included with the SPD-S which contains the factory data, you can download the file here:
http://www.rolandus.com/products/pro...37&ParentId=61
Click the downloads tab and select the "SPD-S Factory Restore Data" (PC or Mac) link.
I think it helps.
If you have any query regarding this issue leae a feedback we were happy to assist you.
Have a Nice Day!
Oct 14, 2009 | Roland Spd-S Sampling Percussion Pad...
Mc909 work station problems
problems with automatic volume sometimes is cause by leaky/corroded pushbuttons.the other impending defect of the circuit itself.i suggest you bring or have a tech check your unit just to be in the safe side.
May 28, 2009 | Roland Mc-909 Sampling Groove Box System
Load Screen Freeze w/ Roland VS-2400
The hard drive needs to be replaced. You can contact their customer service as to how to do this. It is relatively pain free and inexpensive as well.
323-890-3741
Mar 19, 2009 | Roland Vs2400CD Digital Workstation W/CD...
16 step pads at the bottom are sticking or inoperable
yeah call roland support and order the pads... i just fixed mine... the pads are 12.00 each 1-8 and 9-16
Dec 13, 2008 | Roland Mc-909 Sampling Groove Box System
Headphone jack output
The same problem here. I solved it like this:
You must open the device. There will be a PCB with outputs and inputs. You must must detach it by removing screws on outside and then disassemble the PCB from two plastic pins to get the PCB rotated (I used plice to detache it one by one) and the conections of jack socket visible. In my case one od the lanes to the hot pin was broken. I checked that with Ohm meter 'cause it wasn't clearly visible with an eye. So having the PCB more or less secured I started to clean the lane a little bit to have a chance to put the solder layer near the pin and breakage. Get some really precise soldering device. It's a precise job. Do not overheat the diode which the lanes goes to. After placing some of the solder I checked the new connection by placing a jack into the socket and Ohm meter once again. All was perfect and working after assembling. Piece of cake.
ZIBI
Jul 16, 2008 | Roland Mc-909 Sampling Groove Box System
Roland Mc-909 Sampling Groove Box System Logo
214 people viewed this question
Top Roland Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
 Grubhead
Grubhead
Joseph Mueller
Joseph Mueller
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
