Question about Philips 220CW8FB 22" LCD Monitor
How to off smart image
Awd
Posted on Dec 09, 2012
Where is the switch to engage smart track on my 2002 Oldsmobile Bravada?
The Olds Bravada is full time AWD. There is no switch, it is either working or it doesn't and needs service.
Jan 13, 2017 | 2002 Oldsmobile Bravada
Bravada smart track problems
The non-functioning Smart Trak could be just one observable concern while there could be others less obvious.
Jan 09, 2014 | Cars & Trucks
Hi.! I bought a Honda cr-v model 2003 and did not have manual book,how cal i tell if its two wheel drive or front wheel drive.is there an indication where can i look? Thanks..
Depends on the model, if it is all wheel drive it should have AWD on the back window.
The Honda CRV uses very smart technology to have AWD. Let me explain it simply. The CRV is essentially a front wheel drive car, but there are sensors mounted on all the tires that sense slipping. If the computer determines the wheel is spinning faster than the other ones, it uses hydraulics to engage the rear end differential and presto..All Wheel Drive. You do nothing, no switches, no levers, the computer does it all for you. If it is indeed AWD, you can look under the car to see if you have a driveshaft going into the rear differential (axle)
Please vote if this helped! Thanks, Mike
Jun 12, 2011 | 2003 Honda CR-V
All well drive message on dash board " AWD disabled"
The problem is the AWD rear flow valve. Put drain pan under rear differential, unhook connector, unscrew flow valve bolt and pull it out. Reverse order to install. You will need to refill with 4 pints of versatrak fluid (unscrew fill plug) because when you remove the flow valve, all the versatrak fluid comes out. You can only get versatrak fluid at any GM dealership. Do not reuse old nasty versatrak fluid because that is why it got plugged up in the first place.
[img src="http://i.fixya.net/uploads/images/4c9bc0d6-7852-494f-be3d-ff1226269051.jpg" alt="4c9bc0d6-7852-494f-be3d-ff1226269051.jpg">
Posted on Nov 16, 2014
May 24, 2011 | 2005 Buick Rendezvous
I have a 1998 oldsmobile bravada smart trac and the awd service light is on and awd doesnt work
Chains in transfer case are really bad to wear out. Any strange noises?
Jan 10, 2011 | 1998 Oldsmobile Bravada
Low power and missfire, have replaced bad distributor and rotor. 2000 Oldsmobile Bravada AWD. Where are the fuel pump and filter located?
I have replaced Distributor cap, rotor, wires, and spark plugs in my 2000 Oldsmobile Bravada AWD smart track. To replace one spark plug I had to collapse the steering column, but everything went O.K. Did you marked the wires?. Did you reconnect them in the firing order?
The fuel pump is located In the fuel tank. Remove the fuel tank and take the fuel pump out from the top. This is part cost $300 and need some skills to be replaced.
The fuel filter it is directly in front of the fuel tank. Another one is incorporated with the fuel pump.
Sep 10, 2010 | 2000 Oldsmobile Bravada
Replaced the starter , truck started , ran for a minute , shut it off , thried to restart it and it just clicks... i'm confused
is your battery dead? not to be a smart *** but it can happen. Is the starter solenoid replaced also?
May 03, 2010 | 1997 Ford Explorer AWD
My AWD doesn't work. I have a broken wire on my
definately repair that wire. now keep in mind that that particular wire is called a shielded wire and you need to be clean and careful when you repair it. make sure it is water tight and protected. this wire is for the abs wheel speed sensor and with no reading, the abs is inoperable which will affect the awd. the abs and smart trac work in conjuction with each other to help you remain stable. cheers.
Dec 22, 2009 | 1998 Oldsmobile Bravada
1999 olds bravada smart trac four wheel dosent engage
Probably the transfer case encoder motor. Unplugging it at the wiring harness should make the "service awd or smart trac" light come on. This will tell you the awd controller module is probably OK. Common failure item to Bravada's. Try "thepartsladi" eBay store for lowest price motor, beware aftermarket!!! Also make sure transfer case fluid is "blue" GM Auto-Trak II only! If not bllue when checking change twice after driving for a week with blue fluid.
Oct 21, 2009 | 1999 Oldsmobile Bravada
Transferring from 2wd to awd?
The Bravada has the Smart Track Automatic 4WD system, so the computer will automatically engage the front wheels when traction is needed. Hope this helps!!!
Jun 29, 2009 | 1998 Oldsmobile Bravada
Philips 220CW8FB 22" LCD Monitor Logo
168 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
