Question about BenQ 55.L7501.001 Main Board 48.L7501.A04
The board has 4pins for the power supply connector. Wich pin is for what? The board is in a Dell monitor
How to connect the raidmax rx-730ss power supply to the gigabyte ga-z97x-gaming 3 (rev.1.0) motherboards 'ATX_12V_2X4' port?
The 2 plugs are seaparte because many mainboards do not have the 8-pin CPU power plug. Use the second 4-pin on the side of the connector.
Aug 02, 2014 | Gigabyte Computers & Internet
Power supply for a gateway GT5634H
Hi Debbie ,
Yes that power connector should be just fine the extra 4pins are an addition 12v rail to reduce the amperage on one line , you can just connect it offset to one side, not centred.
allthough there will be more current than the newer 24pin PSU, id reccomend buying an additional 20 to 24pin adaptor from
https://www.amazon.co.uk/StarTech-com-6in-Motherboard-Power-Adapter/dp/B0002GRQRW
hope this helps .
Dec 29, 2012 | Computers & Internet
How to check Samsung 732N 17 inch Monitor Power supply module
Open the case, open the main power supply board out and check the dc volts on the pins of the connector to the VGA board the volts are written in the board
Nov 28, 2011 | Samsung 732N 17" Monitor
I replace my power supply for my E520 and its dose not turn on. It is a new replacement power supply for this model. I check alll the connections. It haas aa blinking amber light all time.
I would double check the connections to the main board. Some power supplies have two power connectors to the mother board, a 20 pin connector and a 4 pin connector. Sometimes the four pin connector is in a different location from the 20 pin on the board. Make sure both connectors a plugged in.
Make sure the connector for the power switch is plugged into the board. Dell's usually have all the wires for the front pane in one connector.
You should also unplug everything from the board except the power supply and front panel. There could be a hard device causing the board to hang up.
I have had power supplies die and short the main board. I hope that isn't the case here.
Jul 02, 2011 | Dell DimensionTM E520 PC Desktop
Need spare no: 308615-001 for HP Compaq d330uT computer.Show picture and assembly instruction
search this site...
http://www.sparepartswarehouse.com/Compaq,Computer,Part,308615001.aspx
power supply
to motherboard..
put the power connector to power socket of the motherboard..plus the 4pins connector to the 4pins socket into motherboard..
put the power connector of power
Oct 25, 2009 | Compaq D330 PC Desktop
I change the power supply but i have a little problem. The new one on the ATX power connector have only 19 pin then 20 old one plus extra 4 pin for something else. The new power supply in Rosewill...
The extra 4 pins on the power supply's atx connector is for new motherboards that require 24pin power supplies. If your motherboard has a 20pin port, then only connect the 20pin portion of your power supply connector.
If your power supply has a 24pin fixed connector that can't be split into a 20+4pin configuration, and your motherboard doesn't have space to let the extra 4pins on the side, then you might want to consider returning the power supply and change it for one that can be used as a 20 or 24pin. Otherwise you will need to cut the extra 4pins apart.
Jan 05, 2009 | ASUS P4B533 Motherboard
Problem with motherboard MSI P35 Neo2-FR
suggest not, if you really wan try, go ahead, but i suggest not.
Jun 05, 2008 | Intel Motherboard
CTX Panoview 630 Monitor
Panoview 630 Power Connector pinouts:
It has been many years since the question was posted but who knows, maybe this will help someone. Looking at the end of the connector clockwise from 1-oclock position:
1pm:NC
3pm:+12
5pm: no pin
7pm:+5V
9pm:+5V
11pm:GND
shield is GND
+5V@3A
+12V@1.5A
(you can modify an Apple ADB cable to work)
Mar 15, 2007 | CTX Panoview 630 Monitor
BenQ 55.L7501.001 Main Board 48.L7501.A04 Logo
22 people viewed this question
Top BenQ Televison & Video Experts
Electro Med Services...
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
