Question about Texas Instruments TI-89 Calculator
Hey my ti-89 calculator won't turn on, i tried pressing all the buttons and putting new batteries but it doesn't help. how do i go about fixing it, i remember before it broke i used to hear like a scratchy sound that sounds like rice or something.
  • onomou
    onomou May 11, 2010
    When did you hear the scratchy sound? Was it in the keys when you would press them down, or inside running free?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Try a hard reset: Press and hold the 2nd, left-arrow, and right-arrow keys. Press and release the ON key. Be aware that this will clear all RAM.
Posted on Jan 17, 2010
My calculator just shut off while i was using it, i replaced the triple A batteries but now it still won't turn on, how can i fix it?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and hold the 2ND key. Press and hold the + key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Mar 15, 2012 | Texas Instruments TI-89 Calculator
There is always a blue line showed up in the middle of screen for my daughter's TI-89 Titanium calculator and froze other functions. Change battery does not solve the issue. Really need help. Billy
I think the blue line is generally unfix-able without replacing the screen, which costs as much as a new calculator. The freezing may be fixable, try taking out the triple A batteries and leaving the calculator to sit with them out for a minute or so, replace them and check if it's fixed. If that doesn't work you can do the same but take out the small button back up battery as well. If you're still not having luck you should call ti cares (800-842-2737) they're usually helpful.
Aug 06, 2011 | Texas Instruments TI-89 Calculator
My ti-89 is frozen, no matter what keys i press.and although i took off 4 batteries, but when i put batteries back, it is still same, menu screen.
First try the reset code which is pressing Left-Right-Shift and On at the same time. If that doesn't work you can try removing the batteries and putting them back in while holding the (-) and ) buttons.
If those don't work, there is a back-up battery located under a panel just above the four normal batteries underneath the battery cover. Removing this in addition to the four normal batteries should reset your calculator entirely.
If none of these work then there may be a short in the circuits of your calculator which could have been caused by leaking batteries. In this case you can try disassembling the calculator (being careful to remember how it goes back together) and cleaning the circuit board with circuit cleaner.
Jun 03, 2011 | Texas Instruments TI-89 Calculator
My Ti 89 won't turn on an I put brand new batteries in
TI calculators have a habit of dimming the screen contrast when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and hold the diamond key and press the the + key to darken the screen. If you go too far, use the diamond and - keys to lighten the screen.
If this doesn't do it, please reply to this post and we can try more drastic measures, though they may cause the loss of memory.
Mar 23, 2011 | Texas Instruments TI-89 Calculator
My TI-89 Titanium won't turn on!
A hard reset will clear all memory and should give you back control of the calculator.
1. Put the batteries in the calculator.
2. Press and hold left arrow, right arrow, and 2nd keys.
3. Press and release ON.
Jan 15, 2010 | Texas Instruments TI-89 Calculator
TI-89 won't turn on, even w/ new batteries
Try a hard reset:
Press and hold the 2ND, Left, and Right keys.
Oct 04, 2009 | Texas Instruments TI-89 Calculator
I've spilled some liquid on my Graphics Calculator TI-89 and after that I can't turned it on.Do you know how I can fix it?
Take the batteries out and wait a couple days for it to dry. put batteries in and see if it works. If it doesn't, make sure the batteries are good and if they are, then you need a new calculator. (if only the screen is damaged then you could try to replace it, but you would be hard pressed to find a new one and install it)
ps. don't try to sell it online as a functioning calculator because any buyer can return it with shipping costs on you.
Sep 03, 2009 | Texas Instruments TI-89 Calculator
Hi my ti-89 won't turn on, i've tried putting in new batteries
Try a hard reset. Be aware that his will clear all RAM. Press and hold the 2nd, left-arrow, and right-arrow keys. Press and release the ON key.
Jan 02, 2009 | Texas Instruments TI-89 Calculator
TI-89 Backup Battery
Usually you will be able to re-install everything. And I would try uninstalling the program first then if that doen't work just pull the batteries out and put them back in or just press the reset button. Hope this helps. =)
Feb 24, 2008 | Texas Instruments TI-89 Calculator
Screen Solid Balck
Hey, if this is a ti-89, press green diamond button, then -, keep going and it soguld fix itself
Sep 01, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
117 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
