Question about Vehicle Parts & Accessories
Cant get acc. to turn on with remote start
Fan wont turn on in 2000 bonneville ssei when remote started. followed wiring diagram says to connect to orange wire there are 4 of them and none of them work. is there another wire that i am supposed to use
  • blondeguy0 Jan 04, 2009
    thank you very much
U NEED TO HOOK UP YOUR 2ND ACC
Posted on Jan 03, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I need a wiring diagram for a factory alarm system on a 93 Bonneville SSEi
If you bypassed it at the ignition switch and not at the Theft Deterrent Module, you have only bypassed a portion of the system. Go to this link for info on the subject.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jul 02, 2012 | 1993 Pontiac Bonneville
Hi i have a 2000 bonneville ssei supercharged 3.8 my car keeps choking up when i push on the gas pedel and on the highway on cruise at 80kms keep sputtering and get a black smoke from my exaust and...
i had a 91 gmc car, it was fuel injected &(if it was carburated) ran like the choke was stuck,i changed the thermostate sensor & relay(relay cost more)sounds like your car.the computer was getting information that the car was cold.if you can find a manual for your car check trouble shooting. i dont want to plug a company but HAYNES makes a quality manual.hpe this helps
Apr 09, 2011 | 2000 Pontiac Bonneville
I HAVE 1993 BONNIVILLE WITH A 3.8L.CAR RUNS ABOUT 20 MINUTES THEN SHUTS OFF.SOMETIMES IT STARTS RIGHT UP BUT THEN SOMETIMES IT WONT START UNLESS YOU LET IT SIT FOR AWHILE.
I have a 1995 SSEI,it had the same problems.It was the ignition control module.It's located under your coil packs with a large wiring harness connected to it.307c59b.jpg
Dec 14, 2009 | 1993 Pontiac Bonneville
Interrior lights stay on
are your dasboard lights at full brightness?Turn your headlight switch(it may be on the interior light detent).BTW I drive a '97 Bonneville SE and one great thing about these cars is that if you leave a light on it will shut off after about 5 minutes so it won't drain your battery overnight.
Oct 04, 2009 | 1997 Pontiac Bonneville
My 1997 pontiac boneville SSEI cooling fans never come on
Hey i have a 96 Bonneville SE :) I had the same problem....., First off .
Unplug you're fans.. Take some wires, ( i used speaker wire. ) Have someone help you, :) connect it to you're fan and then to the battery one to ground one to power. If you're fan doesn't turn on then you're motor in the fan is dead.
2nd. Check you're relays, Easy way to do this is switch them around one by one... They can't all be bad :P and if it turns on.. then you have a bad relay:P
3rd. Does you're Temp gauge work? There are a few sensors That could need to be replaced.
Sep 04, 2009 | 1997 Pontiac Bonneville
Vehicle Parts & Accessories Logo
144 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
