Question about Homelite Garden
Homelite chainsaw 246y
Lx-30
5 Suggested Answers
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
SOURCE: homelite chainsaw starts and runs for about 30
Check your fuel lines for cracks it may be sucking air ,also make sure the fuel filter is still attached since they like to come off in the tank and then dirt gets in the carb,if thats the case replace your fuel lines and filter ,replace with fresh fuel (correct mixture ratio is a must). You may want to take the carb apart and clean out the small internal screen it has and look for any cracks in the diaphrams.You should also check your exhaust to make sure its clear of carbon build up.I repair saws , trimmers and many other 2 strokes and find most of the time its bad fuel lines and carbon in the exhaust port,but also alot of times I find damaged pistons and scored cylinders with very little compression.Good luck to you.
Posted on Aug 12, 2009
dontbother10
  • 2220 Answers
SOURCE: set carb homelite chainsaw mod ut 10939
No response to CR.
Posted on Mar 13, 2010
  • 4088 Answers
SOURCE: Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
Posted on Jul 14, 2010
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
What is the gas /oil mix ratio for a homelite bandit lx 30 chainsaw
40:1...
(Remember, it's always better to he over than under...also, GET Alco no smoke...it's the best and cleanest oil mix out... it covers EVERY ratio as well, takes out the guesswork)
Oct 30, 2015 | Homelite Garden
HOMELITE 4618C CHAINSAW WON'T RUN
How long has the chainsaw been sitting? How long has it been sitting with the same gas in it? Typically, most chainsaw and weedtrimmer repairs are fuel related. More times than not, simply draining the old gas, and putting brand new fresh mixed fuel just purchased from the gas station will fix most non start problems. Many people will not believe me, but after 20 years of fixing small engines, i've fixed 70% of the chain saw and string trimmer and related sized engines by putting in new fuel. Fuel goes bad now a days in 30 days. So if the fuel in the gas can sitting in the garage is older than 30 days it is old when you are considering trying to use it in a small engine. Fuel in a car will not cause the same issues as quickly for several reasons. If the fuel in the gas can is older than 30 days get rid of it. If after changing the fuel out completely doesn't fix your problem, feel free to contact me and I'll see if I can help you out.
Sep 02, 2012 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Why does a 2 cycle engine smoke excessively?
Two reasons: Wrong mix and worn parts. You dont say what your mix is (please refer to your owners manual for the proper mix) nor how old your Homelite is. The number will usually be between 30 and 50 PPM. You must measure carefully.
Use only the type and grade oil recommended for your Homelite.
Sep 02, 2011 | Homelite Garden
Chainsaw bar chain adjuster for homelite lx-30 bandit replacement part
if you need parts
try taking a look at web site www.chainsawr.com they will more than likely have what you need
note they can supply secondhand parts in good order at a good price
cheers
Nov 21, 2010 | Homelite Mighty Lite Blowervac
What is the gas-oil mixture for Homelite 360. It is about 25-30 years old.
chainsaws are 40:1
3.2 oz 2-cycle motor oil per gallon gasoline
Oct 26, 2010 | Homelite ZR10926 16" Chain Saw
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
303 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
