Question about Fisher and Paykel Washing Machines
I have a fisher and pykel top loader model GW611, when starting on any cycle, on filling the maching the water will pause every so often and may not fill. when it decides to, it starts beeping and shows the 3 solid lights inbetween long and short wash and if it does manage to fill it may or may not decide to agitate and will also not spin sometimes.
  • Fisher and P... Expert
  • 555 Answers
Your fault code is 112
Info for your fault code.
112. (01110000) Motor Current Sense Too High
This fault occurs if the Motor Control Module detects that the motor current has reached an
unrealistically high level for greater than 2 seconds. This suggests that the motor current
sense circuit is faulty.
Primary source: Motor Control Module.
Action: Replace Motor Control Module.
Posted on Dec 19, 2013
4 Suggested Answers
  • 343 Answers
SOURCE: Fisher and paykel GW611 excellence top loader wont
Check Out Of Balance switch This will prevent spinning and programme from advancing
Posted on Apr 18, 2010
  • 713 Answers
SOURCE: washing machine stopped during spin cycle
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Posted on Jul 27, 2010
Jahn27
  • 1554 Answers
SOURCE: Our FnP GW611 while filling
The problem can be determined through the Wash Progress LEDs. The specific lit LEDs combination indicates an specific error code that tells what generally the problem is. But the exact positions of the lit LEDs are necessary in determining the exact code. Refer to the illustration below and post back the code or the exact positions of the lit LEDs. You may Google for the error code once you determine it, like "Fisher and Paykel Fault Code 37".
Posted on Aug 21, 2011
What does the fault code 66 on a fisher and pykel
The problem with the washer is that the motor controller has sensed the lack of water in the machine as so to speak, hence the error.
If you disconnect your water hose off the backside of the washer there may be screens behind them. I would start there. Good Luck
Oct 18, 2014 | Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
What is fault code 136 on fisher & paykel gw611 washing machine
first thing to look at is the sensor either faulty or corroded connection block if good or a new one doesnt fix it then most likely the main computerboard fault
Jan 12, 2012 | Fisher and Paykel GWL11 Top Load Washer
Washing machine stopped during spin cycle. now when i turn it on it beeps and has 3 lights on, 2 wash lights and the spin light. model number is GW611 excellence. fisher & paykel top loader
Jul 27, 2010 | Fisher and Paykel Washing Machines
Fisher & Paykel GW611 Not filling with water
Hi just read your posting.Did you remove any wires to the control module which is located under the top panel when you replaced the bearings.Now did you put the cold inlet hose to the water valve marked with the letter C and the hot to H ?These letters are next to the valves.Have you got the Efficiency option button?Can you select a manual water level instead of just an auto fill?Have you tried to put the machine throe a spin cycle?Do you hear any water coming into the machine at all?Please with additional information to these questions and I am sure we can rectify this problem for you.
Jun 28, 2010 | Fisher and Paykel Fisher & Paykel Washer
Intermittent water flow interupted by solenoids pulsing
I've got the same problem. If I pause the cycle, wait about 10 seconds, and then resume, the water starts normally. I suspect the Cold Water Inlet Solenoid is sticking, probably due to water sediment in the solenoid causing it to stick. I'll try cleaning it and then replace if that doesn't help and let you know what happens.
Sep 22, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
156 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
