Question about Panasonic PT-43LC14 Television
Abnormal Voltage on 30 V line
I am getting 5 orange flashes every 5 seconds and it would seem that indicates abnormal voltage on 30 V line. This makes sense since the person I got it from blew the bulb this way. I replaced the bulb and am wondering if there is something else I can do or if I need to reset anything, etc.
SOURCE: runtime error that says abnormal program termination
i tried and it worked like this
deinstall windows sp 3
download microsoft 2008 c++ library
install vcs 1.0
install update vcs 1.0 may 2008 from panasonic support
Posted on Jun 02, 2009
  • 197 Answers
SOURCE: Blinking orange power on indicator & solid red lamp indicator
bad lamp  part # ty-la1000
Posted on Jun 09, 2009
asnowman
  • 788 Answers
SOURCE: I have a Panasonic PT-44LCX65 TV for the past 3
If the buld is intact and did not explode, then you should be OK. You just need a new lamp. If the bulb is not intact, then you may have more problems like a damaged color wheel.
I hope this information allows you to resolve this issue.
I am doing this for free.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Jan 31, 2010
SOURCE: the same I just replaced the bulb with a generic one and reset the counter. Now, the tv will work for about 3 minutes before it shuts off. the lamp light indicator goes on and off once every 5 seconds
THERE IS A SERVICE BULLITIN FROM PANASONIC TO REPAIRE THE BALLAST YOU MUST GO TO A PANASONIC SERVICE CENTER
Posted on Jun 14, 2010
ahmosea
  • 47 Answers
SOURCE: Panasonic pt 50lc13 Ballast update done Bulb blew
The door switch is in the front. The switch is triggered when you put the lamp door cover back on. It is a switch thats spring loaded so when you put the lamp door back on it automatically presses the switch.
If you have any other questions please feel free to ask.
Posted on Feb 09, 2011
In canon ipf 750 Error 03130031-2618
this is what i am finding out from other fixya site members so if this helps you out its them you need to thank...
Follow these steps :Cause: The Voltage of the print head is abnormal.
Problems can be with:
-Printhead -head relay PCB -Carriage relay PCB -Main controller PCB
Steps to be followed:
1. Replace the printhead. 2. Cable continuity check. if continuity of the cable between the head relay PCB and the carriage relay PCB is abnormal, replace the cable. 3. Replace the head relay PCB. 4. Cable continuity check. if continuity of the cable between the carriage relay PCB iand the main controller PCB is abnormal, replace the cable. 5.Replace the carriage relay PCB. 6.Replace the main controller PCB...
In my knowledge the error indicates the voltage on the print head is abnormal. It is an hardware related issue.
Possible cases can the print head is faulty or the relays to the PCB may be faulty or the PCB itself.
We have to perform continuity checks between the relays and between relays and PCB. then we can confirm if the relay is faulty or the cables between them . If not print head would have failed and needs to be replaced...
Hardware error. 03130031-2618
Turn off printer, wait, then turn on again.
03130031-2618 VH voltage error
Check the power supply unit
Oct 26, 2017 | Canon Office Equipment & Supplies
Fujitsu asta12lcc timer flashes 5 times
From the service manual:
Serial forward transfer error during the operation
When the outdoor unit does not receive the signal for 10 consecutive seconds during the operation > Outdoor unit stops.
[Diagnosis Point]
Check the indoor /outdoor cable connection (in order). If the cable wiring is not abnormal, measure the voltage of the outdoor unit terminals and diagnose the defective location.
(Refer to the after mentioned [Serial Signal Diagnosis] for the voltage measuring method and diagnosis method.)
Jan 17, 2017 | Fujitsu Heating & Cooling
I have a fujitsu air con which is flashing 3 times on the timer. It runs for 10 seconds and then shuts down and then flashes 3 times. Model is a AOTR09LCC
Serial signal (reverse) error, during operation.
Try turning power off at isolator for ten minutes and then switch back on. If error code persists, you will probably need a new controller PCB in the outdoor unit.
When the indoor unit does not receive the signal for 10 consecutive seconds during the operation >Permanent stop after 30 seconds.
[Diagnosis Point]
Feb 19, 2015 | Fujitsu Heating & Cooling
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Toshiba estudio 351c error code ce40
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color.
(2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to
check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M
and C, and under 220 for K are defined as low-density pattern abnormality.
(3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to
check if the high-density pattern abnormality occurs for each color and identify the color which
pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality.
(4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "0" (Invalid).
(5) Perform "Enforced performing of image quality open-loop control (05-394)".
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(7) Replace the image quality sensor.
(8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid).
(9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Apr 12, 2011 | Toshiba Office Equipment & Supplies
KDL-40XBR4 bought 1/08. Turns on for 30 seconds with screen staying dark. Then it goes off automatically with the stand-by light blinking 5 times repeatedly. Took it to the shop and he said the LCD panel...
KDL- Bravia blink codes (Australian):
2 times-Main power supply voltage error (12V, etc)
3 times-Malfunction of 3.3V line
4 times-Malfunction of 5V line
(Voltage Supply to FE, etc)
5 times-Malfunction of power supply for screen
6 times-Malfunction of inverter or overcurrent, etc
7 times-Abnormal temperature inside unit
8 times-Audio circuit error (amplifier, etc.)
9 times-Fan malfunction
10 times- Digital FE circuit error
11 times-Malfunction of Trident IC or around IC
12 times-BH board error
13 times -Malfunction of balancer
If this is correct the 5 blinks is the power supply having problems, I would much rather change the PS than replace the screen. Also if screen is determine bad, look for class action lawsuit on Sony for defective screen, i am told they know all about this.
Mar 06, 2011 | Sony Televison & Video
I am repairing a 14 inch color tv. there is abnormal voltage at the anode of HT. i have even started seen blue arc all over the rubber cap. i adjusted the HT voltage, but still the same. what could be the...
You say abnormal voltage. What is the voltage? It should be no higher than 25KV, so don't touch it!!
If it is arcing the usual cause is moisture getting in or contamination destroying the insulation.
Measure the EHT and let me know the make and model number. I shall see if I can help.
Jan 20, 2011 | Televison & Video
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
All off led flashes 5 times only and just repeats at mains reset
Accordingly, the 5 blinks is a fault code that means the voltage in the main power is abnormal.
  1. Unplug the unit for 15 minutes while checking the voltage on the AC outlet using a multimeter.
  2. If the voltage is not as what it should be, use a different outlet or have it checked by a qualified electrician.
  3. If the voltage is normal, check the power supply unit for any bad capacitors. Here are the samples of bad capacitors.
Nov 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia 46 shutting off a blinking 6 times
here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Sep 11, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Panasonic PT-43LC14 Television Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
